request for explanation
Bacillo
Post by Bacillo »
I'm back.
Now that I managed to import a catalog, I try to learn good use of the ANC.
then ask:
The highlighted box in the picture, what is it to select it? The menu prints the selected films are called: "ABILITATI", but I do not understand what they are entitled.
Uploaded with ImageShack.us
thanks[/img]
Post by soulsnake »
You mean AMC I think...
It is like you want. You can check/unchek checkboxes (left click on checkbox) or change color (right click on checkbox).
In scripts and print window, you can also use checked movies instead of selected movies or all movies.
I think you mean <untitled> in main window title ?
This is the name of your catalog.
When you will save it, you will see the name of your catalog.
Abilitati = checked
i.e. a "checked" movie is a movie with a small square in the box (maybe we should do something looking more like a checkmark, or at least a "x"?)
As soulsnake said, you can later use the checked/unchecked state of these movies for filtering.
You use for the meaning that you want; e.g. seen/not yet seen, available/not available, etc.
Bacillo
Post by Bacillo »
ok, je comprends
thank you
:hihi: :hihi:
