Variable with script return error in new version 4.1.0
linux2299
Post by linux2299 »
Hi, I've made a report with a variable that mark the most recently added movies in this way, in the script box I've written:
if [Date]>((Date)-90) then
tmp1 := '*'
tmp1 := ' '
and then in the Memo box, I've put the [tmp1] variable.
This run perfectly in 3.8.0 release, but in the new releases it returns: "An error occured during calculating [tmp1] Report: frReport1 Band: Master data"
Why? does the syntax has changed in newer versions?
Thank you
Post by soulsnake »
It should works.
I just modifid some things to add custom fields support.
Can you send me your report template ?
I will try to find and fix the problem.
linux2299
Post by linux2299 »
How can I send it to you?
Post by soulsnake »
You can send me it by mail: mickael.vanneufville@gmail.com
Edit:
Ok I found and fix the bug.
It will be fixed in next version ;).
Sorry.
Soulsnake
linux2299
Post by linux2299 »
Thanks a lot! Can you also answer me to the questions I've added in the mail I've sent to you?
Thank you so much
