Image and Cover help
Bacillo
Post by Bacillo »
I need help.
I installed the 3.512 version of AMC.
With this version I have imported a archio created by XMM (Extreme Movie
Manager).
So I upgraded to the latest version of AMC (4.xxx).
The file was imported correctly.
The problem is that the covers are not visible.
Can I import a imamgine at a time.
I do not know where to set a directory that contains all imamgini.
I used the emnù prefernze-folders, but despite what the pictures are not
visible, if not select them one at a time from: Select a cover (Shift-F7).
Does anyone know how I can fix?
thanks
The images appeared correctly in the catalog in v3.5 but not in v4 ?
What file format do you use, .amc or .xml ?
Where did you save the file ?
Are the picture in the catalog or stored as external files ?
Bacillo
Post by Bacillo »
The images do not display it with version 3.5 with version 4 it.
Appear if I update the film with a script for the Internet.
The image formats are. Jpg I used to import the archive file EMM: *. Mdb
The image files and I have them all saved in a directory
Are external files
Bacillo
Post by Bacillo »
I tried doing a clean install.
Oracle on Windows XP with VirtualBox
I first installed the 3.5 version
I copied the archive file *. Mdb Extreme Movie Manager and entire directory with pictures. These files I've saved close to the installation of ANC.
Then I proceeded to import.
But AMC does not know how to tell where to take pictures.!
Bacillo
Post by Bacillo »
Ok I solved ...
But I did not know how to solve, the fact is that now all the images are visible.
PS version of AMC used: 4.0 beta
ciao
:hihi: :hihi: :hihi: :hihi: :hihi:
