[UPD DE] Filmstarts
J
[UPD DE] Filmstarts
Post by J »
Hi there,
a new year, a new page redesign, a new script which should appear in the script list soon. It´s supposed to work again as usual.
btw:
filmstarts.de is part of the french allociné group and the script should work easyly - with a couple of small changes - on the other group portals like spanish www.sensacine.com
The former script version (v2.0.2) may also work with little changes on www.screenrush.co.uk
I have not tested this, but the group sites look pretty much the same. Maybe only some translations to do for somebody interested.
have fun.
J.
J
Post by J »
another script update to v2.2. The script now needs AMC v4.2
-fixed image import
-fixed description & comments
-added actor images import
-added producer, writer and composer
you can get it from scripts dl page.
cheers
J.
Rubberduck
Post by Rubberduck »
Where do i get AMC 4.2?
Latest version available is 4.1.2.3 (at least on the net...).
J
Post by J »
It´s still BETA.
You can dl the latest version here:
viewtopic.php?t=4844&start=0&sid=8cc710 ... c7bbfb3a8e
mwb
Filmstarts script
Post by mwb »
Hi J,
the script 2.1.1 does not find original AND translated title. So I've tried the script 2.2 in AMC 4.2 beta - same problem.
Cheers mwb
J
Post by J »
right, it seems they have changed the page again.
I´ll try to fix this asap.
thanks
J.
J
Post by J »
Another update to v2.2.1
- fixed title import, user critics and PWC double names
- changed AMC min. version back to v3.5.1 (actor pics and PWC needs v4.2)
- merged PWC (producer, writer, composer) into one option
you can get it from scripts dl page soon.
mwb
Possible Extension?
Post by mwb »
Thank you for your quick response and the 2.2.1 - works fine.
Any chance to have the 'FSK-Freigabe' stored in a field so that it will be easier to find matching movies for kids?
mbw
J
Post by J »
Oooops, haven´t seen that info yet :shocked:
well yes, I´ll include this and store it in the field "certification" (AMC 4.2 only) with next version.
J
Post by J »
Fast update to v2.2.2
- fixed user critics, title pick, rating
- Certification (FSK) added
As usual, use update script or dl from script page.
have fun
J.
mwb
Great
Post by mwb »
Thank you. Top J(ob)
J
Post by J »
update to v2.2.3
- code cleanup
- Now imports Actor images even when option Actors is set to 0
- Added Batchmode
soon avail. for dl.
have fun
J.
J
Post by J »
update to 2.2.6
- fix for producer, writer, composer (PWC)
- added support of more than one composer
cheers
J.
mwb
Post by mwb »
Hi J,
2.2.6 is not working any more. Can you help?
Cheers
J
Post by J »
hi mwb,
currently I also sometimes had connection errors.
hm, perhaps something with their internal search function or their webserver. I´ll take a look on this and try to fix the script if possible/necessary.
The script itself seems to be working right when collecting the data or is there some information wrong or missing?
cheers
J.
Hallo mwb,
es scheint momentan etwas Probleme mit der Verbindung zu geben, manchmal funktioniert das script, manchmal bekomme ich einen connection error.
Ich werde das mal prüfen und gegebenenfalls das script anpassen wenn nötig.
Das Datensammeln an sich sollte aber noch funktionieren oder gibt es hier auch einen Fehler?
grüße
J.
mwb
Post by mwb »
Hallo J,
schalte auch DE um :hihi:
Website ist erreichbar, im Script passiert NULL, keine Fehlermeldung, Wartemode - that's it
P.S. danke für die schnelle Reaktion 1+ :)
J
Post by J »
Ich habe zur Zeit auch sehr lange Wartezeiten beim Aufruf der Seiten im Browser z.B. http://www.filmstarts.de/kritiken/neust ... en/?page=1
und bei der Suche nach Filmtiteln (ca. 1min).
Habe mal die Filme "Tusk" und "Mortdecai" mit dem script getested und nach mehr oder weniger Wartezeit (connected-Fenster teilw. >1min) kommt dann bei mir meist das (Teil-)Ergebnis. Evt. hilft vorübergehend wiederholtes Aufrufen des scripts. Da das script mehrere Seiten aufruft und scheinbar jede Seite lange Wartezeit hat, gibts auch manchmal timeout error.
Da scheint momentan serverseitig etwas nicht ganz rund zu laufen.
Es wurden/werden aber auch einige Änderungen an den Seiten vorgenommen, werde die dann asap im script nachziehen.
Bis dahin bitte noch etwas Geduld.
schönes wochenende
J.
J
Post by J »
update to v2.2.7
- fixed composer
- deletes actors name from role "(as ...)"
soon avail. for dl.
greetings
J.
@mwb
Momentan läuft es wieder etwas besser mit der Seite, alle Testfilme haben nun funktioniert.
Thanks, it is now available from the server
