A problem with audio codec recognition
Bialy-
Post by Bialy- »
Hello,
I've updated my AMC to 4.1.0.2 recently and I noticed a problem - when i drag a movie file to AMC window to fill video and audio format, lenght and file size fields, the audio codec is not recognized properly. It's filled with "2000" for AC3 codec and "0055" for MP3...
Is this a bug in AMC? I've installed K-Lite Codec Pack but it didn't change anything. I'm using Windows 7 now, if it matters.
I would be very grateful for help, greetings :)
Post by soulsnake »
I think you don't have file 'Codecs.ini' in data folder: '%PROGRAMDATA%\Ant Movie Catalog'.
Can you tell me if this data folder exists and if you have file 'Codecs.ini' ?
Bialy-
Post by Bialy- »
Indeed, you're right :) I didn't have one. I've copied 'Codecs.ini' from my backup and now it works fine.
Thanks a lot! :) :grinking:
