you must update OFDb - IMDb (DE)
otherwise you can't get the category, country, actors, audio format, aspect ratio, comments.
here is the new version 1.8.2
which version did you use as basis for your script?
It has the same number as the one posted here: viewtopic.php?t=4941
but it is different since it does not include the TMDb added option...
gerol
basis for the new script is the version, I have posted here:
viewtopic.php?p=32610&highlight=#32610
the version in your post is not from me
The author of the TMDb mod merged the two scripts, so it is now available as version 1.8.3 on http://update.antp.be/amc/scripts/
So if you make other changes in the future, please use that one as basis
