new script is not visble
skidiver
Post by skidiver »
Hello,
I created a new script as a first tryout and for later personal use. The script only contains two lines and works so far. I also filled out the script's properties, but it is not visble inside the scripts list.
What's the error?
Thx,
skidiver
In the script properties there is a "Get info" option that can be set to true if the site is made for getting info from a web site. Only these appear in Movie -> get info -> from script. All scripts are visible in Tools -> Scripting, so you should be able to find your script from there.
skidiver
Post by skidiver »
Thank you, this solves the problem. I read about this option inside the help but I misunderstood the paragraph.
