"Filters" suggestion
Jgat
Post by Jgat »
First of all, sorry for my bad english. An second, congratulations for your program.
It would be nice that AMC would have and advanced search/filter feature. I have seen this feature in GCstar and it's very useful. You can add several criteria selecting field, condition (contains, does not contain, range, =, <, >, regular expression, etc), value; movies matching all criteria (AND) or movies match at least one criterion (OR). And the best of all, you can save the filter with a name and you can put in the toolbar the saved searches as a dropdown list for selecting one filter when you need it.
Thanks for your attention, and dedication to this program.
Improving the search is planned for a future version.
Jgat
Post by Jgat »
Ok, thanks.
