Aprovechando estas mejoras, noto en falta un pequeño suplemento, poder abrir los ficheros con los programas determinados. Poder elegir diferentes programas para diferentes formatos... y en mi caso, poder montar imagenes ISO de forma automatica ya que los *.ISO me los monta el VirtualCloneCD automaticamente.
¿Seria posible poder abrir los ficheros desde esta pantalla?.
Ya he probado el AntViewerCatalog. No muestra todas las imagenes. Y lo mas importante, en red, es muy lento al cargar catalogos grandes. Ademas, en un unico programa tendriamos casi todo...
Edu
I've been very impressed with the improvements included in this new version.
Taking advantage of these improvements, I feel at fault a small fee, you can open the files with certain programs. Being able to choose different programs for different formats ... and in my case, to mount ISO images automatically as the *. ISO mounted VirtualCloneCD to me automatically.
[img] http://mickaelvanneufville.online.fr/AM ... _thumb.jpg [/ img]
Would it be possible to open the files from this screen?.
I've tried the AntViewerCatalog. It shows all the images. And most importantly, a network is very slow when loading large catalogs. Furthermore, in a single program would have almost everything ...
edu
