Hi and first of all congratulations on this program.
I don't know if I have found a bug or it is just that I am doing something wrong. I have created a custom field called "Fichero".
Tag: Fichero
Type: URL
Import media Info:Path+File Name+extension
when I Get information from the file the field fichero is blank (not filled). On the other hand if instead of Import media info:=Path+File Name+extension I set only Path, it works perfectly well
Is it a bug or is it just that I am doing sth wrong?
I forgot to say that I am working under windows 7 64
Bug importing file path????
