Fout in scenario
Locked
DnDuffe
Fout in scenario
Post by DnDuffe »
Hello,
I have tried everything to get it working again.
But I can't import scripts anymore.
I tried to update = not working
tried to delete and replace with copy text = not working.
removed program and reinstall = not working.
Current message =
Fout in scenario "moviemeter": unit is not found in regel 4.
(other scipts don't work aswell)
Please can anyone help me? :cry:
DnDuffe
Post by DnDuffe »
the problem was that one part was in program files and the other in program data.
Now I have bumped onto the next problem.
older spots moviemeter can find but al the new spots are not found.
script is updated.
Is there a maximum of 250?
Post by soulsnake »
If you uninstall AMC 3.5.1, it is possible that some prefs / scripts / templates in 'Program Files\Ant Movie Catalog' or '%LOCALAPPDATA%\VirtualStore\'Program Files\Ant Movie Catalog' are not deleted because they have been added after install.
If you install AMC 4.1.0 in same folder than old AMC 3.5.1, all prefs / scripts / templates that have not been deleted have to be deleted or moved in '%PROGRAMDATA%\Ant Movie Catalog'.
'%PROGRAMDATA%\Ant Movie Catalog' is now (v4.1.0) default data folder to avoid problems of rights with Windows Vista / 7.
Warning 1: Files 'prefs.xml' and 'default.xml' have to be ONLY in '%PROGRAMDATA%\Ant Movie Catalog' and NOT in 'Program Files\Ant Movie Catalog' or '%LOCALAPPDATA%\VirtualStore\'Program Files\Ant Movie Catalog' otherwise program thinks it is a portable version and it uses wrong path for data folder !!!
Warning 2: If you don't unistall AMC 3.5.1 before install AMC 4.1.0, AMC 4.1.0 will install as AMC 3.5.1 (portable version) so '%PROGRAMDATA%\Ant Movie Catalog' it is not used in this case and should not exists !!!
DnDuffe
Post by DnDuffe »
but i updated the sript.
It does not error anymore but he can't find the film anymore
Post by soulsnake »
The script MovieMeter seem to not work very well or it is me who don't enter a good movie title.
DnDuffe
Post by DnDuffe »
yep my problem aswell.
now i need to seek a other good belgium/dutch one
Post by soulsnake »
You should signal the problem here: viewtopic.php?t=4905 ;)
pele
Post by pele »
Send private message Hi,
New script moviemeter is doing nothing. I does't find any film at all.
Kr. Bianca
script updated for the search page change
(version 2.8.02)
follow up on viewtopic.php?p=33601#33601
Locked
