Hi
I´ve my video files in individual folders for each film. Is it possible to rename the name of the folder (or of the files) with this format?
Translated name (year)
Renaming folders or files
See viewtopic.php?t=4460 which seems to do what you want
edit:
but I see that I already gave you that URL on viewtopic.php?t=4765
edit:
If you have the full path of movie file in a field you can use the script RenameFiles to rename files.
You can download last version here: http://mickaelvanneufville.online.fr/AMCU/scripts
This script has been done by myself for my personnal use at the beginning. So use it with caution.
First, use script option to choose how to format the new file name.
When you run the script, first choose the field where the file name is stored.
Second, you can enter folder path if you just have the file name stored and not full path (it is my case).
This last option works only if files are in the same specified folder.
For your case you need to have full path of file in a field and leave folder path option blank.
You can also modify script for your personnal use.
z3us
I didnt remember that, sorryantp wrote:Hi,
edit:
Pumprdlicek
Hi,soulsnake wrote:If you have the full path of movie file in a field you can use the script RenameFiles to rename files.
I tried use your script to rename my files, but it doesn't work. I tried to change code little bit and I think script doesn't take value from ExtractFilePath(filename) and it doesn't matter which options I choose in GenerateFilenameWithGetOptions. Everytime it's same.
Example:
OriginalTitle - Cloudy with a Chance of Meatballs 2
TranslatedTitle - Zataženo, občas trakaře 2
Result, if I choose field selection by TranslatedTitle - [0003] Zataženo, občas trakaře 2 [Cloudy with a Chance of Meatballs 2] 2013.avi
Will you try this?
You can also modify script for your personal use.
Authors=Fulvio53s03
Title=crea nomi films
Description=crea nomi films
Site=
Language=?
Version=1.1
Requires=4.1
Comments=After importing informations from movies contained in a folder and after importing informations about movies from internet...... this Script will Rename your movies' file names (contained in field File Path) using these optional criterias: 1) Translated Title or original Title or Formatted Title 2) Director (Between Brackets) 3) Year 4) Languages i.e. from "Y:\Film\Film da catalogare\The Machinist (2004) 1080p.mkv" you can obtain ""L'uomo Senza Sonno (The Machinist) (Brad Anderson) 2004 ENG, ITA, ENG.mkv". Using it, you will obtain a file named c:\rename.bat.txt (or any other name you choose) that you can open with notepad, control it, rename in c:\rename.bat and then execute it. The script can updates field File Path in Catalog or leave it unchanged (default), Obviousely...... be careful!!!
License=GPL
GetInfo=0
RequiresMovies=1
Title=1|1|0=Formatted Title|1=Translated Title|2=Original Title
Director=1|1|1=Yes|0=No
Year=1|1|1=Yes|0=No
Languages=1|1|1=Yes|0=No
Update_path=0|0|1=Yes|0=No
[Parameters]
program CreaNomiFilm;
StringUtils1;
MovList: TStringList;
DupList: TStringList;
NewName, estensione: string;
ResultPath: string;
Titlenew, Linguaggi, CampoAnno, OldPath, NewPath: string;
Titolo, Regista, Anno, Lingue, PosBar, Aggiorna_path: integer;
Giri, giri_fatti, lgth_path, ctr_variati: integer;
Procedure ChangeLanguages;
Linguaggi := AnsiUpperCase(Linguaggi);
Linguaggi := StringReplace(Linguaggi, 'ENGLISH', 'ENG');
Linguaggi := StringReplace(Linguaggi, 'SPANISH', 'ESP');
Linguaggi := StringReplace(Linguaggi, 'FRENCH', 'FRA');
Linguaggi := StringReplace(Linguaggi, 'ITALIAN', 'ITA');
Linguaggi := StringReplace(Linguaggi, 'GERMAN', 'DEU');
procedure Elaborazione;
NewName := '"';
if Titolo = 1
then NewName := Newname + Getfield(fieldTranslatedTitle);
if Titolo = 2
then NewName := Newname + Getfield(fieldOriginalTitle);
if Titolo = 0
then NewName := Newname + Getfield(fieldFormattedTitle);
if regista = 1
then NewName := NewName + ' (' + Getfield(fieldDirector) + ')';
CampoAnno := Getfield(FieldYear);
if Anno = 1
then NewName := NewName + ' ' + CampoAnno;
Linguaggi := Fulltrim(Getfield(FieldLanguages));
ChangeLanguages;
if length(Linguaggi) > 0
then Linguaggi := ' ' + Linguaggi;
if Lingue = 1
then NewName := NewName + Linguaggi;
estensione := getfield(fieldvideoformat);
if (estensione = 'AVC') or (estensione = 'mkv')
or (estensione = 'avi') or (estensione = 'asp')
or (estensione = 'mp4')
then ctr_variati := ctr_variati + 1
else ShowMessage('errore estensione ' + Newname);
then NewName:= NewName + '.mkv';
if (estensione = 'avi') or (estensione = 'asp')
then NewName:= NewName + '.avi';
if estensione = 'mp4'
then NewName:= NewName + '.mp4';
OldPath := getField(FieldFilePath);
lgth_path := length(Oldpath);
If Aggiorna_path = 0
then lgth_path := 0;
If lgth_path > 0 then
PosBar := AnsiLastPosEx('\', OldPath, true, true);
if PosBar > 0 then
delete(OldPath, (posbar + 1), (lgth_path - PosBar)); //cut old filename
Newpath := Oldpath + stringReplace(NewName, '"', '');
SetField(FieldFilePath, Newpath);
if length(getField(FieldFilePath)) > 0 then
Titlenew := 'ren "' + OldPath + '" ' + NewName + '"';
DupList.Add(Titlenew)
NewName := StringReplace(NewName, '"', '');
Titlenew := NewName;
DupList.Add(Titlenew); //scrivi riga
//MAIN PROGRAM
if StringUtils1_Version < 3 then
ShowMessage('File "stringutils1.pas" is too old, please download a new version of it');
Error;
if ResultPath = '' then
ResultPath := 'c:\rename.bat.txt';
Input('Update/Aggiorna Films', 'Store results to: / Salva Risultati in: ', ResultPath);
Titolo := GetOption('Title');
Regista := GetOption('Director');
Anno := GetOption('Year');
Lingue := GetOption('languages');
Aggiorna_path := GetOption('Update_path');
if Aggiorna_path = 1 then
ShowMessage('Attenzione! State per modificare il campo "file path" dei film nel Catalogo! Advertence! You are going tu update field "file path" in Catalog!');
if Aggiorna_path = 0 then
ShowMessage('Attenzione! Il campo "file path" dei film nel Catalogo non verrà aggiornato! Advertence! Field "file path" in Catalog will not be updated!');
giri := GetiterationCount;
if MovList = nil then
MovList := TStringList.Create;
if DupList = nil then
DupList := TStringList.Create;
Elaborazione;
giri_fatti := GetIteration;
if giri_fatti = Giri-1 then //fine elaborazione
Titlenew := 'pause';
DupList.SaveToFile(ResultPath); //chiudi file
