I want to use [String Insert] action.
When I have a list of files - and I only want to rename SOME of the files - I use the mouse to select the files that I want to work with and click [Go]. The [String Insert] action is applied to ALL of the files in the list - not just the selected files.
Am I seeing the expected behavior? Or should Ant Renamer respect the file selections that I made?
Thank you,
Synlap
Should [String Insert] respect file selection?
