Error SHIFT+CTRL+V between databases (Version 4.1.0 beta)
cinecampillos
Post by cinecampillos »
Why I can't paste data between databases? In previous versions, I do Shift+Ctrl+C to copy data from a movie, I close database, I open a new database and I do Shift+Ctrl+V to restore data from the copied movie.
Post by soulsnake »
Actually, copy/paste works great but just for opened catalog.
I have changed this because of dynamic custom fields.
I will try to modify this this week-end to have the same behavior than before ;).
cinecampillos
soulsnake wrote:Actually, copy/paste works great but just for opened catalog.
Thank you. This feature is very useful to me. Actually I am working with multiple databases and copy/paste records from one to another with ease.
Post by soulsnake »
The copy/paste of a movie works now with multiple catalogs.
You can test it in new release.
cinecampillos
soulsnake wrote:The copy/paste of a movie works now with multiple catalogs.
Again, Soulsnake, thanks. I will try it.
visent
Post by visent »
Hi!
I can't copy/paste between catalogs, has desactivated this function??
Thank's
Post by soulsnake »
What version of AMC do you use ?
Do you really paste values of a copied movie on another movie ?
In last version of AMC 4.1.2.3, all work great for me.
visent
Post by visent »
soulsnake wrote:Hi,
Ajá, ok. I has trying copy/paste whitout movie in the other catalog. Before I have to have a empty movie created.
Thanks!!!
:grinking: :grinking:
