Before I started using Ant, I tried Griffith, but because of some issues, I switch. But in Griffith there were two options, I miss in Ant. 1) A simple "seen/haven't seen" button were you can mark if you have seen the movie or haven't done it yet. 2) A form of wish list or DvD is intend to buy soon. Both options should have their own icon in the overall list.
Hope it is something you would consider implementing.
Request.
You can use the checkbox in front of the movie to indicate if it is seen or not.
In the next version (4.1) there are custom fields that can be defined, so you can add these two info as custom field, and then using the "group by" feature to show the seen/unseen/wish in three different groups.
Alternatively you can use the color tags (also in version 4.1) to assign a different color to the checkbox of the movies depending if they are seen/unseen/wish.
That new version is available as beta/test version from the forum: viewtopic.php?t=4844
