the same category for more than one movie in one step
Y-rr
Post by Y-rr »
i use the amc database to import my film in myfilms plugin for mediaportal. i want to manage the film in mediaportal by self-created categories. the category of the films will not imported by the script, the option is disabled.
now i want to create categories for some films. i cannot fill in something in the field "category" if i select more than one movie. how can i do this for the movies in one step?
thx
y-rr
Raoul_Volfoni
Post by Raoul_Volfoni »
Try the "Update Fields (FR-US).ifs" script, if you not already have it, it's available here
(Place this script in your AMC script directory.)
Little tutorial :
- Select your movies from the AMC list.
- Then start the "Update Fields (FR-US)" script.
- Choose "delete a field" in the list.
- Then choose "category" in the list.
- Answer "yes" to the next question.
- And finally enter your value.
Hope this help
Y-rr
Post by Y-rr »
OK, i'll try this.
Is there a Script with i can copy the content from a field to an other field? exactly the same content.
Raoul_Volfoni
Yes, the same as above, and you choose "copy field1 in field2" in the first list when you start the script.
Y-rr
Post by Y-rr »
the field in which the content should be copied is media label. but there is no media label in the second window.
Post by soulsnake »
I think you use AMC 3.5.1.
You can download AMC 4.1.0 [BETA] and run script UpdateField (it has been updated for this new version and takes into account all fields).
Y-rr
Post by Y-rr »
Thx, now it works.
