AMC stand alone
Sprfnc
AMC stand alone
Post by Sprfnc »
I use this program since the early versions and I find it very good. But lately are around and not always have my computer with me that a version of "stand alone" to keep on a USB stick would be really helpful, I not only to me.
Raoul_Volfoni
Post by Raoul_Volfoni »
You just have to install the program on your key.
Personally, I just extract the rar archive (available here) on my key.
Indeed, the install does only basic tasks:
- copy the files to target folder
- create shortcut icons
- associate .amc files with the program
- add uninstall info to windows
so you could install it on a usb key and it will work on all computers, but it is probably better to simply download the rar file and extract it manually.
Sprfnc
Post by Sprfnc »
Thank you for the advice and will install the USB stick.
PS. Sorry if there's a few mistakes but I'm Italian and English do not have much familiarity.
