FilmAffinity (ES) [Fix]: Oficial version v2.51
aviloria
Post by aviloria »
Hi all,
Thank you for the comments and the feedback from the previous release.
I have fixed a small bug: The script could not retrieve "Country filed" when there is no "Visual section" in the html code of the page.
You can find the new version at the bottom of the post.
Hola a todos,
Gracias por los comentarios y las aportaciones de la versión anterior.
He corregido un pequeño problema: El script no podía obtener el campo "País" cuando no existía una "Sección visual" en el código HTML de la página.
Authors=aviloria  (aviloria@yahoo.com) modded by: rodpedja (rodpedja@gmail.com), kreti (bisoft@hotmail.com), MrK, gilistico
Title=FilmAffinity (ES)
Language=ES
Version=2.51
Requires=3.5.0
Comments=Updated: Script option for batch running (default disabled), and now it gets the category.
program FilmAffinity;
   BaseURL1 = 'http://www.filmaffinity.com';
   MovieURL: string;
   Result := -1;
   if StartAt < 0 then
      StartAt := 0;
         Result := i;
   InitialPos: Integer;
   if InitialPos = 0 then
      result := ''
      InitialPos := Pos(EndTag, S);
         result := S
         result := Copy(S, 1, InitialPos - 1);
         Delete(S, 1, InitialPos + 1);
   n, len, tag: Integer;
   c: char;
   t: String;
   tag := 0;
   t := '';
   len := length(s);
   for n :=1 to len do
      c := Copy(s,n,1);
      // quitamos los tabuladores
      if c = #9 then c := ' ';
      if tag = 1 then
         if c = '>' then tag := 0;
         continue;
         if c = '<' then
            tag := 1;
            continue;
         t := t + c;
   s := t;
   result := t;
   Line,Line2: string;
   Count: Integer;
   Count := 0;
   Page  := TStringList.Create;
   // Veamos si solo hay un solo resultado
   LineNr := FindLine('<b>1 resultados.</b>', Page, 0);
   if LineNr <> -1 then
      Line         := Page.GetString(LineNr + 7);
      Line2        := Line;
      MovieAddress := TextBetween(Line, '<b><a href="', '">');
      MovieTitle   := TextBetween(Line2, '.html">', '</a></b>');
      HTMLDecode(MovieTitle);
      DeleteTags(MovieTitle);
      if (MovieAddress <> '') AND (MovieTitle <> '') then
         MovieAddress := BaseURL1 + MovieAddress;
           if PickTreeExec(MovieAddress) then
              AnalyzeMoviePage(MovieAddress);
         if GetOption('DontAsk') = 1 then
   // Veamos cuantos resultados se han encontrado
   LineNr := FindLine('resultados.</b></td></tr>', Page, 0);
      Line  := Page.GetString(LineNr);
      Count := StrToInt(TextBetween(Line, '<b>', ' resultados.</b>'), 0);
   // Si no hemos encontrado ningún resultado, abandonamos
   if Count = 0 then
      ShowMessage('No se ha encontrado ningún registro');
   LineNr := 0;
   while TRUE do
      LineNr := FindLine('<b><a href="', Page, LineNr + 1);
      if LineNr = -1 then
         LineNr := FindLine('<b>siguientes >></b>', Page,0);
         if LineNr = -1 then
            break;
         Address   := TextBetween(Line, '<a href="', '">');
         LineNr    := 0;
         continue;
      Line2        := Line;
      MovieTitle   := TextBetween(Line2, '.html">', '</td>');
         PickTreeAdd(MovieTitle, BaseURL1 + MovieAddress);
      AnalyzeMoviePage(Address);
   Item: string;
   Comments: string;
   Actors: string;
   Directors: string;
   Comments := '';
   Actors := '';
   // URL
   // Translated Title
   LineNr := FindLine('<div style="margin-bottom: 4px; padding:1px; text-align: left; border-bottom: 1px solid #990000;"><span style="color:#990000; font-size:16px; font-weight: bold;">', Page, 0);
   Item := TextBetween(Line, ' border="0"> ', '</span>');
   HTMLDecode(Item);
   SetField(fieldTranslatedTitle, Trim(Item));
   // Original Title
   LineNr := FindLine('<th>TÍTULO ORIGINAL</th>', Page, LineNr);
      Item := TextBetween(Line, '<td><strong>', '</strong></td>');
      HTMLDecode(Item);
      SetField(fieldOriginalTitle, Trim(Item));
   // Year
   LineNr := FindLine('<th>AÑO</th>', Page, LineNr);
      if (Pos('</div>', Line) > 0) then
        Item := TextBetween(Line, '</div>', '</td>')
        Item := TextBetween(Line, ' ', '</td>');
      HTMLDecode(Item);
      SetField(fieldYear, Trim(Item));
   // Length
   LineNr := FindLine('<th>DURACIÓN</th>', Page, LineNr);
      Line := Page.GetString(LineNr + 5);
      Item := TextBetween(Line, ' ', ' min.');
      HTMLDecode(Item);
      SetField(fieldLength, Trim(Item));
   // Country
   LineNr := FindLine('<th valign="baseline" align="right" ><b>PAÍS</th>', Page, LineNr);
      if (Pos ('title="', Line) <= 0) then
      Item := TextBetween(Line, 'title="', '" border');
      HTMLDecode(Item);
      SetField(fieldCountry, Trim(Item));
   // Director
   LineNr := FindLine('<th>DIRECTOR</th>', Page, LineNr);
      Directors := '';
      while Pos('stype=director', Line) > 0 do
         Item := TextBetween(Line, '">', '</a>');
         HTMLDecode(Item);
         if Directors = '' then
            Directors := Item
            Directors := Directors + ', ' + Item;
      SetField(fieldDirector, Trim(Directors));
   // Script writer
   LineNr := FindLine('<th>GUIÓN</th>', Page, LineNr);
      Item := TextBetween(Line, '<td>', '</td>');
      Comments := Comments + 'Guión: ' + Item + #13#10 + #13#10;
   // Composer
   LineNr := FindLine('<th>MÚSICA</th>', Page, LineNr);
      Comments := Comments + 'Música: ' + Item + #13#10 + #13#10;
   // Photography
   LineNr := FindLine('<th>FOTOGRAFÍA</th>', Page, LineNr);
      Comments := Comments + 'Fotografía: ' + Item + #13#10 + #13#10;
   // Actors
   LineNr := FindLine('<th>REPARTO</th>', Page, LineNr);
     Line := '';
     while TRUE do
        LineNR := LineNR + 1;
        Line   := Line + Page.GetString(LineNr);
        if Pos('</td>', Line) > 0 then
           break;
     Actors := TextBetween(Line, '">', '</a>') + #13#10;
     while Pos('stype=cast', Line) > 0 do
        Actors := Actors + TextBetween(Line, '"> ', '</a>') + #13#10;
     HTMLDecode(Actors);
     SetField(fieldActors, Actors);
   // Productor
   LineNr := FindLine('<th>PRODUCTORA</th>', Page, LineNr);
      HTMLDecode(Item);
      SetField(fieldProducer, Trim(Item));
   // Official Webpage
   LineNr := FindLine('<th>WEB OFICIAL</th>', Page, LineNr);
      Comments := Comments + 'Web oficial: ' + TextBetween(Line, '<a href="', '" target="_blank">') + #13#10 + #13#10;
   // Awards
   LineNr := FindLine('<th>PREMIOS</th>', Page, LineNr);
      LineNr   := LineNr + 1;
      while Pos('<a href="/es/awards.php', Line) > 0 do
        Item := DeleteTags(Line);
        Comments := Comments + '  - ' + Trim(Item) + #13#10;
   // Category
   LineNr := FindLine('<th>GÉNERO</th>', Page, LineNr);
      HTMLDecode(Item);
      SetField(fieldCategory, Trim(Item));
   // Synopsis
   LineNr := FindLine('<th>SINOPSIS</th>', Page, LineNr);
      HTMLDecode(Item);
      SetField(fieldDescription, Trim(Item));
   // Critic
   LineNr := FindLine('<th>CRÍTICAS</th>', Page, LineNr);
      Comments := Comments + 'Críticas: ' + #13#10;
      LineNr := LineNr + 3;
      Item := Page.GetString(LineNr);
      while Pos ('</tr>', Item) = 0 do
         while Pos('<br>', Item) <> 0 do
            Item := StringReplace(Item, '<br>', #13#10);
         while Pos('</br>', Item) <> 0 do
            Item := StringReplace(Item, '</br>', #13#10);
         while Pos('  ', Item) <> 0 do
            Item := StringReplace(Item, '  ', ' ');
         Comments := Comments + DeleteTags(Item);
   // Picture
   LineNr := FindLine('http://pics.filmaffinity.com/', Page, LineNr);
      Item := TextBetween(Line, '<a class="lightbox" href="', '"');
      if Length(Item) = 0 then
         Item := TextBetween(Line, '<img src="', '"');
      GetPicture(Item);
   // Rating
   LineNr := FindLine('<div style="margin: 4px 0; color:#990000; font-size:22px; font-weight: bold;">', Page, LineNr);
      Item := TextBetween(Line, '<div style="margin: 4px 0; color:#990000; font-size:22px; font-weight: bold;">', '</div>');
      HTMLDecode(Item);
      SetField(fieldRating, Item);
   HTMLDecode(Comments);
   if (CheckVersion(3,5,0) = FALSE) then
      AnalyzeMoviePage(MovieName)
      AnalyzePage(BaseURL1 +'/es/search.php?stext=' + UrlEncode(MovieName)  + '&stype=Title');
Protasio
Post by Protasio »
Muchas gracias
Carlos Burgas
Post by Carlos Burgas »
Uso AMC hace años pero soy nuevo en cuanto a problemas.
Filmaffinity llevaba varios dias que solo importaba 4 o 5 campos y a partir de hoy no encuentra ningun titulo de pelicula.
Por otra parte me gustaría aprender la programación de scripts para resolver los problemas localmente.
¿Me podeis ayudar?
Protasio
Post by Protasio »
Ayer 14 por la mañana funcionaba perfectamente y por la tarde al realizar la búsqueda no encontraba ninguna película.
pedigree
Post by pedigree »
Muchas gracias por el script, pero parece que sigue sin funcionar, no encuentra ninguna película.
rodpedja
Changes in the HTML
Post by rodpedja »
Parece que han cambiado el HTML de la pagina: Estoy revisando el script:
Por ejemplo donde pone ahora
Deberia cambiarse por:
LineNr := FindLine('<strong>1</strong> resultados.', Page, 0);
Pero hay mas cambios.. Cuando lo finalice lo posteo aqui al completo
rodpedja
Post by rodpedja »
Aqui está el script corregido:
Language=ES
Version=2.53
Requires=3.5.0
   MovieURL: string;
   Result := -1;
   if StartAt < 0 then
      StartAt := 0;
         Result := i;
      result := ''
         result := S
   c: char;
   t: String;
   tag := 0;
   t := '';
   len := length(s);
   for n :=1 to len do
      c := Copy(s,n,1);
      if tag = 1 then
         continue;
         if c = '<' then
            tag := 1;
            continue;
         t := t + c;
   s := t;
   result := t;
   Line,Line2: string;
   Count: Integer;
   Count := 0;
      Line2        := Line;
   LineNr := FindLine('</strong> resultados.</div>', Page, 0);
      Count := StrToInt(TextBetween(Line, '<div style="text-align:right;"><strong>', '</strong> resultados.</div>'), 0);
   if Count = 0 then
   LineNr := 0;
   while TRUE do
      if LineNr = -1 then
         if LineNr = -1 then
            break;
         LineNr    := 0;
         continue;
      Line2        := Line;
   Item: string;
   Comments: string;
   Actors: string;
   Directors: string;
   Comments := '';
   Actors := '';
   // URL
   // Translated Title
   LineNr := FindLine('<img src="http://www.filmaffinity.com/images/movie.gif" border="0">', Page, 0);
   HTMLDecode(Item);
   // Original Title
      HTMLDecode(Item);
   // Year
      HTMLDecode(Item);
   // Length
      HTMLDecode(Item);
   // Country
   LineNr := FindLine('<b>PAÍS</th>', Page, LineNr);
      HTMLDecode(Item);
   // Director
      Directors := '';
         HTMLDecode(Item);
            Directors := Item
   // Script writer
   // Composer
   LineNr := FindLine(' <th>MÚSICA</th>', Page, LineNr);
   // Photography
   // Actors
     Line := '';
     while TRUE do
           break;
     HTMLDecode(Actors);
   // Productor
      HTMLDecode(Item);
   // Official Webpage
   // Awards
   // Category
      HTMLDecode(Item);
   // Synopsis
      HTMLDecode(Item);
   // Critic
   // Picture
      GetPicture(Item);
   // Rating
   LineNr := FindLine(' <div style="margin: 4px 0; color:#990000; font-size:22px; font-weight: bold;">', Page, LineNr);
      Item := TextBetween(Line, ' <div style="margin: 4px 0; color:#990000; font-size:22px; font-weight: bold;">', '</div>');
      HTMLDecode(Item);
Que lo disfruten ;)
Protasio
Post by Protasio »
No aparece "País"
Gracias
javienigma
Post by javienigma »
Gracias con la última modificación del script añadida ya vuelve a funcionar. A mi también me pasaba que no me encontraba ninguna película. Ahora con el aporte de rodpedja todo vuelve a la normalidad.
Protasio, no te aparece el país? yo acabo de hacer dos busquedas y si me detecta ok el país...
Una duda, porque si el script es en español, las carátulas salen con los títulos en inglés? hay alguna manera de encontrar la carátula en español, ya sea con filmaffinity u otro script que me recomendeis?
GRACIAS!
pedigree
Post by pedigree »
Muchas gracias rodpejda, el script vuelve a funcionar :)
ChessPlayer
Post by ChessPlayer »
Protasio wrote:No aparece "País"
Gracias
En efecto, en algunas películas no aparece el país :??:
rodpedja
Post by rodpedja »
Habría que cambiar lo siguiente, para que siempre encuentre el país:
 // Country
   LineNr := FindLine('<img src="/imgs/countries', Page, LineNr);
      HTMLDecode(Item);
A ver si saco tiempo para actualizar el script completo..
aas8051
Post by aas8051 »
Acabo de actualizar el script a la versión 3.53 y no carga el año de la pélicula. He modificado la linea 227 y parece que ya la carga.
I've just upgrade this script to ver. 3.53 and it doesn't load the field "year"·. I've modify line no. 227 and it seems to work fine.
227 Item := TextBetween(Line, '</a></div>', '</td>');
Regards
Alberto
Edito: En determinadas películas funciona la versión modificada y en otras la versión sin modificar. :/
Thanks, I updated version number to 2.54 then.
ChessPlayer
Pues ahora lo que ocurre es que cuando encuentra sólo una película no pregunta, pero tampoco baja nada. No da error, pero se queda en blanco. He probado.
Con la película "Sophie Scholl: los últimos días", si pones el título completo no devuelve nada, pero si pones sólo "últimos" te encuentra varias películas, seleccionas la correcta y entonces baja todos los datos.
masterchipo
Post by masterchipo »
dejaron de funcionar para cualquier película todos los scripts, nuevos y viejos de Filmaffinity. Y para ninguna película, ya no se trata del año, ni del país, ni nada, ningun dato te pone, es como si no encontrara nada.
A ver si nos dan una mano que ya están dando bastantes problemas estos scripts.
Sorry but I do not understand Spanish, and the result of Google Translation is not really good :D
For me the current script (2.54) works, at least on the few movies I tested.
@ChessPlayer > you mention "Sophie Scholl: los últimos días" -> that does not give any result on the FilmAffinity website so it is normal that the script does not find it either.
z3us
Post by z3us »
antp wrote:Sorry but I do not understand Spanish, and the result of Google Translation is not really good :D
Antp, they are talking about the spanish version of filmaffinity:
http://www.filmaffinity.com/es
This is the film:
http://www.filmaffinity.com/es/film368669.html
Protasio
Post by Protasio »
En la página web han colgado el siguiente cartel:
"Estamos trabajando en el rediseño de la página
Próximamente en las mejores pantallas :) "
Deberiamos esperar a ver si terminan.
Saludos
masterchipo
Try you film London Boulevard
The script 2.54 don't work
El nuevo script no funciona, y me refiero al 2.54. Hay películas que están en la base de datos y no las encuentra.
Me parece que como la página de FilmAffinity se ha modificado, también hay que volver a modificar el nuevo script, que estaba hecho y pensado por el diseño de la página anterior
Gracias
