hilfer
Posts: 4 Joined: 2011-10-01 09:15:31
Post
by hilfer » 2011-11-12 12:37:44
I'm trying trying to find some movies on my library but the search function seems to be not working at all.
What can be the problem ??
Raoul_Volfoni
Posts: 863 Joined: 2006-08-31 23:58:18
Post
by Raoul_Volfoni » 2011-11-12 19:32:44
Hi
It's strange.
I don't know what to say to help you, except :
Have you ever used the function before and if yes, did it work before ?
Which version of AMC are you using ?
Posts: 9902 Joined: 2002-05-30 10:13:07
Post
by antp » 2011-11-13 21:33:24
Did you check that the right field is selected just above the search box?
Can you give examples, e.g. with screenshots?
hilfer
Post
by hilfer » 2011-11-13 22:30:27
antp wrote: Did you check that the right field is selected just above the search box?
Yes it used to work.
I don't see why it doesn't work anymore.
hilfer
Post
by hilfer » 2011-11-13 22:40:29
Ok I think I found.
When I have the box "EXACT VALUE" checked it doesn work.
Sorry my friends.
and thanks for your assistance
Post
by antp » 2011-11-14 16:09:21
Well, it works but differently
