FilmAffinity (ES): Official new version
aviloria
Post by aviloria »
Hi all,
Sorry for the late, but I have been very busy... ;)
Here you can find the new version for FilmAffinity (ES) script supporting the new web-page design/changes.
Hola a todos,
Perdón por el retraso, he estado un tanto ocupado últimamente.
A continuación os dejo la nueva versión para el script de FilmAffinity (ES) soportando los nuevos cambios de la web.
Authors=aviloria  (aviloria@yahoo.com) modded by: rodpedja (rodpedja@gmail.com), kreti (bisoft@hotmail.com), MrK, gilistico
Title=FilmAffinity (ES)
Language=ES
Version=2.50
Requires=3.5.0
Comments=Updated: Script option for batch running (default disabled), and now it gets the category.
program FilmAffinity;
   BaseURL1 = 'http://www.filmaffinity.com';
   MovieURL: string;
   Result := -1;
   if StartAt < 0 then
      StartAt := 0;
         Result := i;
   InitialPos: Integer;
   if InitialPos = 0 then
      result := ''
      InitialPos := Pos(EndTag, S);
         result := S
         result := Copy(S, 1, InitialPos - 1);
         Delete(S, 1, InitialPos + 1);
   n, len, tag: Integer;
   c: char;
   t: String;
   tag := 0;
   t := '';
   len := length(s);
   for n :=1 to len do
      c := Copy(s,n,1);
      // quitamos los tabuladores
      if c = #9 then c := ' ';
      if tag = 1 then
         if c = '>' then tag := 0;
         continue;
         if c = '<' then
            tag := 1;
            continue;
         t := t + c;
   s := t;
   result := t;
   Line,Line2: string;
   Count: Integer;
   Count := 0;
   Page  := TStringList.Create;
   // Veamos si solo hay un solo resultado
   LineNr := FindLine('<b>1 resultados.</b>', Page, 0);
   if LineNr <> -1 then
      Line         := Page.GetString(LineNr + 7);
      Line2        := Line;
      MovieAddress := TextBetween(Line, '<b><a href="', '">');
      MovieTitle   := TextBetween(Line2, '.html">', '</a></b>');
      HTMLDecode(MovieTitle);
      DeleteTags(MovieTitle);
      if (MovieAddress <> '') AND (MovieTitle <> '') then
         MovieAddress := BaseURL1 + MovieAddress;
           if PickTreeExec(MovieAddress) then
              AnalyzeMoviePage(MovieAddress);
         if GetOption('DontAsk') = 1 then
   // Veamos cuantos resultados se han encontrado
   LineNr := FindLine('resultados.</b></td></tr>', Page, 0);
      Line  := Page.GetString(LineNr);
      Count := StrToInt(TextBetween(Line, '<b>', ' resultados.</b>'), 0);
   // Si no hemos encontrado ningún resultado, abandonamos
   if Count = 0 then
      ShowMessage('No se ha encontrado ningún registro');
   LineNr := 0;
   while TRUE do
      LineNr := FindLine('<b><a href="', Page, LineNr + 1);
      if LineNr = -1 then
         LineNr := FindLine('<b>siguientes >></b>', Page,0);
         if LineNr = -1 then
            break;
         Address   := TextBetween(Line, '<a href="', '">');
         LineNr    := 0;
         continue;
      Line2        := Line;
      MovieTitle   := TextBetween(Line2, '.html">', '</td>');
         PickTreeAdd(MovieTitle, BaseURL1 + MovieAddress);
      AnalyzeMoviePage(Address);
   Item: string;
   Comments: string;
   Actors: string;
   Directors: string;
   Comments := '';
   Actors := '';
   // URL
   // Translated Title
   LineNr := FindLine('<div style="margin-bottom: 4px; padding:1px; text-align: left; border-bottom: 1px solid #990000;"><span style="color:#990000; font-size:16px; font-weight: bold;">', Page, 0);
   Item := TextBetween(Line, ' border="0"> ', '</span>');
   HTMLDecode(Item);
   SetField(fieldTranslatedTitle, Trim(Item));
   // Original Title
   LineNr := FindLine('<th>TÍTULO ORIGINAL</th>', Page, LineNr);
      Item := TextBetween(Line, '<td><strong>', '</strong></td>');
      HTMLDecode(Item);
      SetField(fieldOriginalTitle, Trim(Item));
   // Year
   LineNr := FindLine('<th>AÑO</th>', Page, LineNr);
      if (Pos('</div>', Line) > 0) then
        Item := TextBetween(Line, '</div>', '</td>')
        Item := TextBetween(Line, ' ', '</td>');
      HTMLDecode(Item);
      SetField(fieldYear, Trim(Item));
   // Length
   LineNr := FindLine('<th>DURACIÓN</th>', Page, LineNr);
      Line := Page.GetString(LineNr + 5);
      Item := TextBetween(Line, ' ', ' min.');
      HTMLDecode(Item);
      SetField(fieldLength, Trim(Item));
   // Country
   LineNr := FindLine('<th valign="baseline" align="right" ><b>PAÍS</th>', Page, LineNr);
      Item := TextBetween(Line, 'title="', '" border');
      HTMLDecode(Item);
      SetField(fieldCountry, Trim(Item));
   // Director
   LineNr := FindLine('<th>DIRECTOR</th>', Page, LineNr);
      Directors := '';
      while Pos('stype=director', Line) > 0 do
         Item := TextBetween(Line, '">', '</a>');
         HTMLDecode(Item);
         if Directors = '' then
            Directors := Item
            Directors := Directors + ', ' + Item;
      SetField(fieldDirector, Trim(Directors));
   // Script writer
   LineNr := FindLine('<th>GUIÓN</th>', Page, LineNr);
      Item := TextBetween(Line, '<td>', '</td>');
      Comments := Comments + 'Guión: ' + Item + #13#10 + #13#10;
   // Composer
   LineNr := FindLine('<th>MÚSICA</th>', Page, LineNr);
      Comments := Comments + 'Música: ' + Item + #13#10 + #13#10;
   // Photography
   LineNr := FindLine('<th>FOTOGRAFÍA</th>', Page, LineNr);
      Comments := Comments + 'Fotografía: ' + Item + #13#10 + #13#10;
   // Actors
   LineNr := FindLine('<th>REPARTO</th>', Page, LineNr);
     Line := '';
     while TRUE do
        LineNR := LineNR + 1;
        Line   := Line + Page.GetString(LineNr);
        if Pos('</td>', Line) > 0 then
           break;
     Actors := TextBetween(Line, '">', '</a>') + #13#10;
     while Pos('stype=cast', Line) > 0 do
        Actors := Actors + TextBetween(Line, '"> ', '</a>') + #13#10;
     HTMLDecode(Actors);
     SetField(fieldActors, Actors);
   // Productor
   LineNr := FindLine('<th>PRODUCTORA</th>', Page, LineNr);
      HTMLDecode(Item);
      SetField(fieldProducer, Trim(Item));
   // Official Webpage
   LineNr := FindLine('<th>WEB OFICIAL</th>', Page, LineNr);
      Comments := Comments + 'Web oficial: ' + TextBetween(Line, '<a href="', '" target="_blank">') + #13#10 + #13#10;
   // Awards
   LineNr := FindLine('<th>PREMIOS</th>', Page, LineNr);
      LineNr   := LineNr + 1;
      while Pos('<a href="/es/awards.php', Line) > 0 do
        Item := DeleteTags(Line);
        Comments := Comments + '  - ' + Trim(Item) + #13#10;
   // Category
   LineNr := FindLine('<th>GÉNERO</th>', Page, LineNr);
      HTMLDecode(Item);
      SetField(fieldCategory, Trim(Item));
   // Synopsis
   LineNr := FindLine('<th>SINOPSIS</th>', Page, LineNr);
      HTMLDecode(Item);
      SetField(fieldDescription, Trim(Item));
   // Critic
   LineNr := FindLine('<th>CRÍTICAS</th>', Page, LineNr);
      Comments := Comments + 'Críticas: ' + #13#10;
      LineNr := LineNr + 3;
      Item := Page.GetString(LineNr);
      while Pos ('</tr>', Item) = 0 do
         while Pos('<br>', Item) <> 0 do
            Item := StringReplace(Item, '<br>', #13#10);
         while Pos('</br>', Item) <> 0 do
            Item := StringReplace(Item, '</br>', #13#10);
         while Pos('  ', Item) <> 0 do
            Item := StringReplace(Item, '  ', ' ');
         Comments := Comments + DeleteTags(Item);
   // Picture
   LineNr := FindLine('http://pics.filmaffinity.com/', Page, LineNr);
      Item := TextBetween(Line, '<a class="lightbox" href="', '"');
      if Length(Item) = 0 then
         Item := TextBetween(Line, '<img src="', '"');
      GetPicture(Item);
   // Rating
   LineNr := FindLine('<div style="margin: 4px 0; color:#990000; font-size:22px; font-weight: bold;">', Page, LineNr);
      Item := TextBetween(Line, '<div style="margin: 4px 0; color:#990000; font-size:22px; font-weight: bold;">', '</div>');
      HTMLDecode(Item);
      SetField(fieldRating, Item);
   HTMLDecode(Comments);
   if (CheckVersion(3,5,0) = FALSE) then
      AnalyzeMoviePage(MovieName)
      AnalyzePage(BaseURL1 +'/es/search.php?stext=' + UrlEncode(MovieName)  + '&stype=Title');
[/code]
Thanks ;)
javienigma
Post by javienigma »
Gracias!
