Sorte pictures creating folder with date of file
cotp
Post by cotp »
Hello, and thanks for your great program ;)
To sort some pictures, I would like to create a new folder based on date of file and then move them
In date time I tried /yyyy_dd_mm/fe
it show correct but it doesn't create the folder...
should create exemple: 2011_08_20/name.jpg
Can anyone help me on this ? Maybe I should just create the folder but don't know how... :/
Thanks in advance,
Cotp
PS: can it save the date of the file instead of creating a new one ?
For automatic folder creation you have to enable "force directories" in options -> processing.
The / at the beginning is not needed, and you'd rather use \ than / (though that it may work with a /)
What do you mean by "save the date of the file"?
