Does anyone have a script that will do a silent update i.e. no user responses required after initial selections actioned. I have 100s of films I have imported filenames for, but now want to do the information updates. Current scripts prompt for each film.
Thanks for any help,
John.
Script for silent batch info updates
Irish_john
On batch mode it should run without interaction, though I never used that besides some tests quite a while ago.
Did you check Execution Options "Show results window" and "Close this window at end" for correct settings ?
Which options exactly does the script bring up to select from ? Maybe you need to set DescriptionSelection or some other options too, but I don't remember without looking up the code.
