Hi
I am using AMC for a while and I want to rename my movies according to my movies according to original title of IMDB that stores in AMC. is it anyway to do?
there is some post about renaming and moving but unfortunately didn't work for me
Renaming Filenames Based on IMDB Title
There is viewtopic.php?t=4460
Is that the one you are refering to?
When you say it didn't work, what happened?
There is also viewtopic.php?t=1951 but that one uses the field "source" instead of "url" for retrieving/storing the file path, so the field name in it should be changed.
