starting Renamer by Windows Task-Manager
dybbor
Post by dybbor »
how can I start the Renamer by the Windows-Taskmanager and execute a task automaticly ? (rename a lot of mp3-files with random-option)
Can you help me ?
Many thanks and regards
Robert
I guess it is you who asked me the same by e-mail this morning? :D
Just in case of, what I replied:
Did you check the help file?
There are some command-line options, allowing to specify which
files/folders should be included, which batch file should be loaded,
and if the process should be launched.
