Import from HTML
Bender
Import from HTML
Post by Bender »
Hi, as I needed to reinstall my computer, I exported the database to HTML. While I was doing that, I didn´t know that the program wasn´t able to import the data from HTML. Considering the fact that my database contains 500 items, it is obvious that I would rather not have to add each of them again. Is there any script that would be able to import the data from HTML? I used the following template:
http://i1038.photobucket.com/albums/a46 ... nmka-1.png
Thank you for your help.
That had been done previously, I do not know if it was for that template or not.
But it was years ago so I can't really help you.
Technically it is not difficult to do.
If you know a little programming it is easy to parse that HTML page, with any programming language (even the scripting tool of AMC).
