script for IMDB batch import with large pics (from Amazon)
kolia
Post by kolia »
Since I'm new here, I want to say hi to all of you!
2 days ago I decided to change my movie manager from "DivX Manager" to this one ;)
It looks preety nice, it isn't loaded with useless info, and most off all it's free (thanks Antoine) so I figured this is the one I should stick to from now on, so why not help out a bit...
the "IMDB (batch).ifs" I found on the installation package did not import images, nor did the "amc_scripts.zip" I downloaded help so I decided to make my own effort
here is my script for IMDB batch import with large pics (from Amazon)
(with a few changes preceded by ***)
The Script now:
- imports 1st movie found from IMDB with large pics
*** Replaced //Picture to "IMDB (batch).ifs" with the one from "IMDB (large pic).ifs" and made all the necessary adjustments to the script (declared new variables etc.)
- doesn't import TranslatedTitle (this is what I use to order my movies and it messed things up)
*** "ImportTranslatedTitle = False;
- saves pictures externally
*** all GetPicture(Value, False); --> GetPicture(Value, True);
- not had the time (yet) to work on the "improved" or "beta-fixed" large pic import, I'll give you guys some time to work on it, then try to make my own mix ;))
// SCRIPTING
// IMDB (US) automated batch importing (use Editor to change options)
// Note(!): This script will take first found Movie title, which in some cases
// will mean it will take the wrong movie title. However, this script will
// save you a ton of time when importing info for a large list. Just correct
// the falsely imported infos manually later. Be sure to make a backup of your
// list beforehand.
*  Movie importation script for:                   *
*      IMDB (US), http://us.imdb.com               *
*  (c) 2002 Antoine Potten    antoine@buypin.com   *
*  Improvements made by Danny Falkov               *
*  Improvements made by Kai Blankenhorn            *
*  Batch-import improvements made by Youri Heijnen *
*  Picture-import improvements made by Kolia       *
*  For use with Ant Movie Catalog 3.4.0            *
*  www.ant.be.tf/moviecatalog ··· www.buypin.com   *
*  The source code of the script can be used in    *
*  another program only if full credits to         *
*  script author and a link to Ant Movie Catalog   *
*  website are given in the About box or in        *
*  the documentation of the program                *
program IMDb;
  // Set the following constants to True to import field, or False to skip field
  ImportURL = True;
  ImportOriginalTitle = True;
      LeaveOriginalTitle = True; // True will get Translated Title, yet Original Title field will remain same
  ImportYear = True;
  ImportRating = True;
  ImportPicture = True;
    ImportLargePicture = False; // If set to False small pic will be imported
  ImportDirector = True;
  ImportActors = True;
  ImportCountry = True;
  ImportCategory = True;
  ImportDescription = True;
    UseLongestDescription = False; // If set to False shortest description available will be imported
  ImportComments = True;
  ImportLength = True;
  ImportLanguage = True;
  result := -1;
  if StartAt < 0 then
    StartAt := 0;
      result := i;
  TitleFound: Boolean;
  MovieURL: String;
  if pos('<TITLE>IMDb', Page.Text) = 0 then
    if ImportURL then
    AnalyzeMoviePage(Page)
    TitleFound := False;
    LineNr := 0;
    LineNr := FindLine('<H2><A NAME="top">Most popular searches</A></H2>', Page, LineNr);
    if LineNr > -1 then
      MovieURL := AddMoviesTitles(Page, LineNr);
      TitleFound := True;
    LineNr := FindLine('<H2><A NAME="mov">Movies</A></H2>', Page, LineNr);
    if (LineNr > -1) And Not (TitleFound) then
      TitleFound := True;
    LineNr := FindLine('<H2><A NAME="tvm">TV-Movies</A></H2>', Page, LineNr);
      TitleFound := True;
    LineNr := FindLine('<H2><A NAME="tvs">TV series</A></H2>', Page, LineNr);
      TitleFound := True;
    LineNr := FindLine('<H2><A NAME="vid">Made for video</A></H2>', Page, LineNr);
      TitleFound := True;
    if TitleFound then
      AnalyzePage(MovieURL);
  Line, Value, Value2, FullValue, OldOriginalTitle: string;
  LineNr, Desc, i: Integer;
  BeginPos, EndPos: Integer;
  Descriptions, OldTitleParts: TStringList;
  AmazonPage: TStringList;
  FoundOnAmazon: Boolean;
  // Original Title & Year
  if (ImportOriginalTitle) or (ImportYear) then
    if LineNr > -1 then
      BeginPos := pos('<title>', Line);
      if BeginPos > 0 then
        BeginPos := BeginPos + 7;
      EndPos := pos('(', Line);
      if EndPos = 0 then
        EndPos := Length(Line);
      HTMLDecode(Value);
      if ImportOriginalTitle then
        OldOriginalTitle := GetField(fieldOriginalTitle);
      if (ImportTranslatedTitle) and Not (LeaveOriginalTitle) then
        EndPos := pos(')', Line);
        if ImportYear then
          SetField(fieldYear, Value);
  // Translated Title
  if ImportTranslatedTitle then
    OldTitleParts := TStringList.Create;
    // Tokenize OldOriginalTitle while removing certain chars/common words ("the", "of")
    Value := AnsiUpperCase(OldOriginalTitle);
    Value := StringReplace(StringReplace(Value, ',', ' '), ':', ' ');
    Value := StringReplace(StringReplace(Value, '(', ' '), ')', ' ');
    Value := StringReplace(StringReplace(Value, 'OF', ' '), 'THE', ' ');
    until Pos('  ', Value) = 0;
    Value := StringReplace(Trim(Value), ' ', ',');
    // Value now contains the original title (comma-separated) that was filled in before running the script
    Value2 := '';
    for i := 1 to Length(Value) do
      if Pos(',', Copy(Value, i, 1)) = 0 then
        Value2 := Value2 + Copy(Value, i, 1);
      if (Pos(',', Copy(Value, i, 1)) = 1) or (i = Length(Value)) then
        OldTitleParts.Add(Value2); // put each comma-separated value from Value into a separate string in TitleParts
        Value2 := '';
    for i := 0 to OldTitleParts.Count - 1 do
    // Begin comparing title parts (from the title originally filled in by moviedb owner) with
    // the 'true' Original Title (extracted from IMDb) to see if it's a foreign title and needs a Translated Title
      if Pos(OldTitleParts.GetString(i), AnsiUpperCase(GetField(fieldOriginalTitle))) <= 0 then
      begin // no match, must be a foreign title
        LineNr := FindLine('Also Known As', Page, 0);
        if LineNr > -1 then
          if Pos('Also Known As', Line) > 0 then
            BeginPos := Pos('Also Known As', Line) + 26;
            Value := Copy(Line, BeginPos, Length(Line) - BeginPos - 4);
            Value := StringReplace(Value, '<br>', '/ ');
    OldTitleParts.Free;
  // Rating
  if ImportRating then
    if LineNr > -1 then
      if Pos('/10', Line) > 0 then
        SetField(fieldRating, Value);
  // Direct Link (FIX: when IMDb finds only one entry for the movie title, the script assumes the search URL as Movie URL)
  // Before Fix: http://us.imdb.com/Tsearch?title=Final Fantasy%3A+The+Spirits+Within
  // After  Fix: http://us.imdb.com/Title?0173840
  if ImportURL then
    if Pos('Tsearch', GetField(fieldURL)) > 0 then
      if LineNr > -1 then
        if Pos('/Ratings?', Line) > 0 then
          BeginPos := pos('/Ratings?', Line) + 9;
          Value := 'http://us.imdb.com/Title?' + Copy(Line, BeginPos, 7);
          SetField(fieldURL, Value);
  // Picture
  FoundOnAmazon := False;
  LineNr := FindLine('title="DVD available at Amazon.com"', Page, 0);
  if LineNr > -1 then
    BeginPos := Pos('href="', Line) + 5;
    Delete(Line, 1, BeginPos);
    EndPos := Pos('"', Line);
    AmazonPage := TStringList.Create;
    AmazonPage.Text := GetPage('http://us.imdb.com' + Value);
    LineNr := FindLine('<b>1.', AmazonPage, 0);
    if LineNr = -1 then
      LineNr := FindLine('img src="http://images.amazon.com/images/P/', AmazonPage, 0);
      if LineNr > -1 then
        Line := AmazonPage.GetString(LineNr);
        BeginPos := Pos('img src="http://images.amazon.com/images/P/', Line) + 8;
        Value := StringReplace(Value, 'TZZZZZZZ', 'LZZZZZZZ');
        GetPicture(Value, True); // False = do not store picture externally ; store it in the catalog file
        FoundOnAmazon := True;
      LineNr := FindLine('http://images.amazon.com/images/P/', AmazonPage, LineNr);
      BeginPos := Pos('src="', Line) + 4;
      Value := StringReplace(Value, 'THUMBZZZ', 'LZZZZZZZ');
    AmazonPage.Free;
  if not FoundOnAmazon then
       not found on Amazon, so taking what's available directly on IMDB.
       if we are lucky, a picture from amazon but directly linked in the page
    LineNr := FindLine('<img alt="cover" align="left" src="http://ia.imdb.com/media/imdb/', Page, 0);
    if LineNr < 0 then
      LineNr := FindLine('<img alt="cover" align="left" src="http://posters.imdb.com/', Page, 0);
    if LineNr < 0 then
    if LineNr > -1 then
      BeginPos := pos('src="', Line) + 4;
      EndPos := pos('"', Line);
      Value := StringReplace(Value, 'MZZZZZZZ', 'LZZZZZZZ'); // change URL to get the Large instead of Small image
  // Director
  if ImportDirector then
    if LineNr > -1 then
      FullValue := '';
        EndPos := pos('</a>', Line);
          if FullValue <> '' then
        Delete(Line, 1, EndPos);
      until Pos('</a>', Line) = 0;
      HTMLDecode(FullValue);
  // Actors
  if ImportActors then
    LineNr := FindLine('ast overview', Page, 0);
    if LineNr = -1 then
      LineNr := FindLine('redited cast', Page, 0);
    if LineNr > -1 then
      FullValue := '';
        BeginPos := Pos('<td valign="top">', Line);
          if EndPos = 0 then
            EndPos := Pos('</td>', Line);
            BeginPos := pos('.... </td><td valign="top">', Line);
              EndPos := pos('</td></tr>', Line);
              BeginPos := BeginPos + 27;
              if Value2 <> '' then
                Value := Value + ' (as ' + Value2 + ')';
          Line := '';
      until Line = '';
  // Country
  if ImportCountry then
    LineNr := FindLine('Country:', Page, 0);
    if LineNr > -1 then
      HTMLDecode(Value);
  // Category
  if ImportCategory then
    LineNr := FindLine('Genre:', Page, 0);
    if LineNr > -1 then
      HTMLDecode(Value);
  // Description
  if ImportDescription then
    Descriptions := TStringList.Create;
    LineNr := FindLine('Plot Summary:', Page, 0);
    if LineNr < 1 then
      LineNr := FindLine('Plot Outline:', Page, 0);
    if LineNr > -1 then
      BeginPos := pos('</b>', Line) + 5;
      EndPos := pos('<a href', Line);
      if EndPos < 1 then
      EndPos := pos('<a href="/Plot?', Line);
      if EndPos < 1 then
        EndPos := pos('<br><br>', Line);
      if EndPos < 1 then
      HTMLDecode(Value);
      Descriptions.Add(Value);
      BeginPos := pos('/Plot?', Line);
      EndPos := pos('">(more)', Line);
      Desc := 0;
      if (BeginPos <> 0) and (EndPos <> 0) then
        GetDescriptions(Value, Descriptions);
        For i := 0 to Descriptions.Count - 1 do
          if UseLongestDescription then
            if Length(Descriptions.GetString(i)) > Length(Descriptions.GetString(Desc)) then
              Desc := i
            if Length(Descriptions.GetString(i)) < Length(Descriptions.GetString(Desc)) then
              Desc := i;
      Value := '';
      SetField(fieldDescription, Descriptions.GetString(Desc));
    Descriptions.Free;
  // Comments
  if ImportComments then
    LineNr := FindLine('<b>Summary:</b>', Page, 0);
    if LineNr > -1 then
      Value := '';
        LineNr := LineNr + 1;
        EndPos := Pos('</blockquote>', Line);
        if EndPos = 0 then
          EndPos := EndPos - 2;
        Value := Value + Copy(Line, 1, EndPos) + ' ';
      until Pos('</blockquote>', Line) > 0;
      HTMLDecode(Value);
      Value := StringReplace(Value, #13#10+' ', #13#10);
  // Length
  if ImportLength then
    LineNr := FindLine('Runtime:', Page, 0);
    if LineNr > -1 then
      EndPos := pos(' min', Line);
      if EndPos = 0 then
        EndPos := pos('  /', Line);
      if EndPos = 0 then
      if Pos(':', Line) < EndPos then
        BeginPos := Pos(':', Line) + 1
        BeginPos := 1;
      SetField(fieldLength, Value);
  // Language
  if ImportLanguage then
    LineNr := FindLine('Language:', Page, 0);
    if LineNr > -1 then
      if EndPos = 0 then
  DisplayResults;
procedure GetDescriptions(Address: string; var Descriptions: TStringlist);
  Line, Value: string;
  Page.Text := GetPage('http://us.imdb.com' + Address);
  LineNr := FindLine('<p class="plotpar">', Page, 0);
  while LineNr > -1 do
    Value := '';
        BeginPos := BeginPos + 10
        BeginPos := 1;
      EndPos := pos('</p>', Line);
      if EndPos < 1 then
        EndPos := Length(Line) + 1;
      if Value <> '' then
        Value := Value + ' ';
    until (pos('</p>', Line) > 0) or (LineNr = Page.Count);
    HTMLDecode(Value);
    LineNr := FindLine('<p class="plotpar">', Page, LineNr);
function AddMoviesTitles(Page: TStringList; var LineNr: Integer): String;
  StartPos: Integer;
    StartPos := pos('="', Line);
    if StartPos > 0 then
      Startpos := Startpos + 2;
      MovieAddress := copy(Line, StartPos, pos('">', Line) - StartPos);
      MovieTitle := copy(Line, StartPos, pos('</A>', Line) - StartPos);
      HTMLDecode(Movietitle);
      if Length(Result) <= 0 then
        Result := 'http://us.imdb.com' + MovieAddress;
  until pos('</OL>', Line) > 0;
  if CheckVersion(3,4,0) then
    if MovieName <> '' then
//      AnalyzePage('http://us.imdb.com/Tsearch?title='+UrlEncode(MovieName)+'&restrict=Movies+only');
      AnalyzePage('http://us.imdb.com/Tsearch?title='+UrlEncode(MovieName));
and some questions for antp: please check "What is the Exact Role of Checked/Unchecked? need you help!" under the Help subsection, thanks
Thanks for the script.
So basically you marged the batch script (I know that it was outdated) with the large pic script ?
I'll have to include that with the program next time I update it.
kolia
Post by kolia »
yes, basically this is it, but with a couple of personal changes (Translated Title not imported and image saved externaly)
but now that I tested it again, I just figured that the "ImportOriginalTitle = True;" and "ImportTranslatedTitle = True;" do not work meaning that they are not imported no matter if the value is True or False but this was not my bad (they do not work in the oriignal batch script either :( )
well, I'm too tired to look into it now, maybe some other time :/
