getting started with 1st dvd
jude3048
Post by jude3048 »
how do you get the image of dvd to show on lower left hand corner of program? Do I have to download another part of it? thanks in advance
You either have to provide the image to the program, or get it from a site that provides it (using the scripts, press F6 key or go in movie->get info->from script)
