Using version 3.5.1.2 of AntMovie Catalog, I just imported one set of info for a movie, then I go to do another and I get the message:
http/1.1 404 not found
If I find the page in imdb, and input it in the script, I get the exact same error.
Other scripts just say not found or they simply return no info.
Anyone know what's going on?
IMDB script not working
Please update the IMDb script to version 3.70 available from http://update.antp.be/amc/scripts/ or just run script [ UPDATE_SCRIPTS ].
You can check your current script version in the information frame below the scripts list.
