ID3v2 support?
saxonwolfcock
ID3v2 support?
Post by saxonwolfcock »
I wondered if there was any intention to add support for ID3v2 tags? Currently Ant Renamer only supports v1.1 which only supports up to 30 characters. I use Ant Renamer to rename my music files but it often cuts off the last few letters of the title because of the character limit in the tag.
By the way, I think AntRenamer is a great and simple piece of software, great stuff. thanks
Intention, yes, but I do not know when I will do that.
When I started the program the id3v2 was not so much used, but now it is quite important indeed...
