Script Debugger
UPollaehne
Script Debugger
Post by UPollaehne »
I found the ANT movie database quite usefull and although I am not that familiar with Pascal I would like to create scripts for this fine program.
What currently stops me from creating scripts is the lack of a debugger for scripts where I can at least step line by line through my script, see the values of variables, select the line to run to, select the line to continue from.
I have seen in My InnoSetuP Extensions that is is possible to create a debugger so I am asking if something like this is planned for one of the next releases.
kind regards,
Ullrich.
I do not know if it is possible with Innerfuse 2 (what I use), but it is possible with Innerfuse 3 (what Inno Setup uses, I think).
I wanted to change to if3 for amc 3.4.1 but it seems that there are lots of changes, so it will probably be for amc 4.
UPollaehne
Good to hear this. So you make me waiting for amc 4. ;-)
