[REQ] Automatic update with IMDB
Michi81
Post by Michi81 »
Hi all,
I'm using AMC since 2004 and I now I was wondering, as many data haven't been updated ever since, if it is possible to update the ratings of the movies in a "simple" way.
I mean.. I check/flag only the "modifiable field" rating, then I include all movies in my selection and I run the script IMDB. Then, for every movie I have to confirm the title, then choose the right title between the various similar titles that the script finds, and so on.. quite demanding if I aim to update 1500 movies.. :)
I'm sure there is a simpler way (dunno, maybe searching for the URL instead that for the title.. but how can I set it?), but I can't find it. Could you please help me? Thank you very much!
Michi
z3us
Post by z3us »
Why dont you enable the batch mode?
Michi81
Post by Michi81 »
Where is it? Thanks. ;)
In the scripts options, in the right panel, above where you chose the fields that can be modified.
Michi81
Post by Michi81 »
Thank you very much! :)
