Script IndexDVD-IMDB V1.1
legrad
Post by legrad »
Version actualizada de la anterior, esta version dispone de pantalla para elegir datos entre IndexDVD y IMDB, logicamente al escoger la opcion IMDB, el script es un poco mas lento ya que tiene que manejar una segunda web la de IMDB de esta descarga el rating y una lista mas extensa del reparto.
Authors=Legrad
Title=IndexDVD-IMDB
Description=
Site=www.index-dvd.com
Language=ES
Version=1.1
Requires=3.5.0
Comments=
License=
 program IndexDVD_IMDB;
  MovieURL: string;
function Comillas(var S: string): string;
   n,len, tag: Integer;
   c: char;
   t: String;
   tag := 0;
   t := '';
   len := length(s);
   for n :=1 to len do
     c := Copy(s,n,1);
     if c = '''' then
        c := ' ';
        t := t + c;
   s := t;
   result := t;
  Result := -1;
  if StartAt < 0 then
    StartAt := 0;
      Result := i;
  InitialPos: Integer;
  if InitialPos = 0 then
    result := ''
    InitialPos := Pos(EndTag, S);
      result := S
      Delete(S, 1, InitialPos + 1);
function Caracter(str1: string) :string;
          str1 := StringReplace(str1, 'á' , 'à');
          str1 := StringReplace(str1, 'é' , 'é');
          str1 := StringReplace(str1, 'í',  'í');
          Str1 := StringReplace(Str1, 'ó', 'ó');
          str1 := StringReplace(str1, 'ú' , 'ú');
          str1 := StringReplace(str1, 'ñ' , 'ñ');
          str1 := StringReplace(str1, 'Ã�', 'Á');
          str1 := StringReplace(str1, 'É', 'É');
          str1 := StringReplace(str1, 'Ã�', 'Í');
          str1 := StringReplace(str1, 'Ó', 'Ó');
          str1 := StringReplace(str1, 'Ú', 'Ú');
          str1 := StringReplace(str1, 'Ñ', 'Ñ');
          str1 := StringReplace(str1, 'Â', '');
result := str1;
end;//------------------------------------------------------------------------------------
   c: char;
   t: String;
   tag := 0;
   t := '';
   len := length(s);
   for n :=1 to len do
      c := Copy(s,n,1);
      if c = #9 then
         c := ' ';
      if(tag=1) then
         if(c='>') then tag := 0;
         continue;
         if(c='<') then
            tag := 1;
            continue;
         t := t + c;
   s := t;
   result := t;
  strPage, MovieAddr, MovieTitle,MovieTitle1, MovieDate, MovieID, Movie: string;
  BeginPos, EndPos: Integer;
  strPage := GetPage(Address);
  BeginPos := Pos('ficha(s) encontrada(s)</b>', strPage);
  if(BeginPos > -1)then
      Delete(strPage, 1, BeginPos);
      BeginPos := Pos('class=''texto3''> <a href=''http://www.index-dvd.com', strPage);
      EndPos := 1;
          EndPos := Pos('title=', strPage);
          MovieId := Copy(strPage,+54, EndPos-54);
          MovieId  := StringReplace(MovieId , '''', '');
          MovieAddr := 'http://www.index-dvd.com' + '/'+MovieId;
          MovieTitle1 := MovieId;
          MovieTitle1  := TextBetween(MovieTitle1 , '/', '-');
          MovieTitle1  := StringReplace(MovieTitle1 , 'blu', 'BLU-RAY');
          MovieTitle1  := StringReplace(MovieTitle1 , 'dvd', 'DVD');
          MovieTitle1  := StringReplace(MovieTitle1 , 'cine', 'CINE');
          MovieTitle1  := StringReplace(MovieTitle1 , 'hd', 'HD');
          BeginPos := Pos('self''>',strPage);
          EndPos := Pos('</a>', strPage);
          MovieTitle := Copy(strPage,BeginPos, EndPos);
          MovieTitle  := TextBetween(MovieTitle , '>', '</a>');
          DeleteTags(MovieTitle);
          MovieTitle := UTF8Decode(MovieTitle);
          PickTreeAdd((MovieTitle+'  ('+MovieTitle1+')'), MovieAddr);
          PickTreeSort;
           BeginPos := -1;
    PickTreeExec(Address)
    AnalyzeMoviePage(Address);
  Item: string;
  Item2: string;
  dir: string;
  Comments: string;
  Actors: string;
  Directors: string;
  Description: string;
  CodigoDelSoporte:string;
  TipoDeSoporte: string;
  Busca: integer;
  Description := '';
  // URL
  // Titulo traducido
  Item := TextBetween (Line, '<title>', 'index-dvd');
  Item := StringReplace (Item, 'Blu-Ray', '');
  Item := StringReplace (Item, 'Cine', '');
  Item := StringReplace (Item, 'DVD Video', '');
  Item := StringReplace (Item, 'HD-DVD', '');
  Item := StringReplace (Item, '|', '');
  // Titulo Original
  LineNr := FindLine('title="Buscar ', Page, 0);
  if LineNr <> -1 then
    Item := TextBetween (Line, '<a href="http://www.movieweb.com/search/?search=', '"');
    HTMLRemoveTags (Item);
    HTMLDecode(Item);
  // año
  LineNr := FindLine('Ficha de', Page, 0);
    Item := TextBetween (Line, '<b>(', ')</b>');
    HTMLDecode(Item);
  // Categoria
  LineNr := FindLine('minutos /', Page, 0);
  if LineNr > 0 then
    Item := copy(Page.Text, pos('minutos /',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '>', '</font>');
    DeleteTags (Item);
    Item   := AnsiUpFirstLetter(Item );
    Item  := Trim(Item );
    HTMLDecode(Item);
   // pais
  LineNr := FindLine('title="Ficha de', Page, 0);
  if LineNr > 0 then
    Item := copy(Page.Text, pos('title="Ficha de',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '#9A9A9A', '</font>');
    DeleteTags (Item);
    HTMLDecode(Item);
   // director
  LineNr := FindLine(')</b></font> / <a href=', Page, 0);
  if LineNr > 0 then
    Item := copy(Page.Text, pos(')</b></font> / <a href=',Page.Text), length(Page.Text));
    Item := TextBetween (Item, 'busqueda=', 'title=');
    Item   := Comillas(Item );
    HTMLDecode(Item);
  // productor
  LineNr := FindLine('>Produce:</font></b>', Page, 0);
  if LineNr > 0 then
    Item := copy(Page.Text, pos('>Produce:</font></b>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '>Produce:</font></b>', '</span></td></tr>');
    HTMLDecode(Item);
  // Duracion
  if LineNr > 0 then
    Item := TextBetween (Item, '</b><br>  ', 'minutos');
    DeleteTags (Item);
    HTMLDecode(Item);
  // Reparto
  LineNr := FindLine('href="http://www.index-dvd.com/calendar_ult.php?', Page, 0);
  if LineNr > 0 then
    Item := copy(Page.Text, pos('class=''link4b''>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, 'class=''link4b''>', '</a><br><br>');
    DeleteTags (Item);
    HTMLDecode(Item);
  // sinopsis
 LineNr := FindLine('Sinopsis</font>', Page, 0);
  if LineNr > 0 then
    Item := copy(Page.Text, pos('Sinopsis</font>',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '#2D2D2D', '</font></td></tr></table>');
    Item := TextBetween (Item, '>', '</font></td></tr></table>');
    Item := StringReplace (Item, #13#10, '');
    DeleteTags (Item);
    HTMLDecode(Item);
  // Caratula
  LineNr := FindLine('[img]http://www.index-dvd.com/covers', Page, 0);
  if LineNr > 0 then
    Item := copy(Page.Text, pos('[img]http://www.index-dvd.com/covers',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '[img]http://www.index-dvd.com/covers', '[/img]');
    Item := StringReplace(Item, '300', '600');
    HTMLDecode(Item);
    GetPicture ('http://www.index-dvd.com/covers'+Item);
//begin
//end;
     // imdb
 LineNr := FindLine('http://spanish.imdb.com/title/', Page, 0);
  if LineNr > 0 then
    dir := copy(Page.Text, pos('http://spanish.imdb.com/title/',Page.Text), length(Page.Text));
    dir  := TextBetween (dir , 'http://spanish.imdb.com/title/', '/');
    dir  := StringReplace (dir , #13#10, '');
    DeleteTags (dir );
    Item  := Trim(dir  );
    HTMLDecode(dir );
    PickListAdd('Descargar Reparto de IndexDVD');
    PickListAdd('Descargar Reparto y calificación de IMDB');
PickListExec(GetField(fieldMedia),Item);
if Item = '' then
SetField(fieldMedia, Item);
if Item = 'Descargar Reparto y calificación de IMDB' then
    Page.Text := GetPage('http://spanish.imdb.com/title/'+dir);
    PickListClear;
 // Calificación
  LineNr := FindLine('<div class="starbar-meta">', Page, 0);
  if LineNr > 0 then
    Item := copy(Page.Text, pos('<div class="starbar-meta">',Page.Text), length(Page.Text));
    Item := TextBetween (Item, '<b>', '/');
    SetField(fieldRating, Trim (Item));
  // Reparto
  LineNr := FindLine('Reparto', Page, 0);
  if LineNr > 0 then
    Item := copy(Page.Text, pos('Reparto',Page.Text), length(Page.Text));
    Item := TextBetween (Item, ';">', '</td></tr></table>');
    Item := StringReplace (Item, '...', ' (');
    Item := StringReplace (Item, '</td></tr>', ')'+#13#10);
    Item := StringReplace (Item, '  ', '');
    DeleteTags (Item);
    HTMLDecode(Item);
Input('IndexDVD', 'Buscar:', MovieName);
     if(GetOption('Sin resultado') = 0) then  Input('IndexDVD', 'Buscar:', MovieName);
   AnalyzePage('http://www.index-dvd.com/calendar_ult.php?tema=&order=tit&busqueda=' + UrlEncode(MovieName)+'&Submit.x=0&Submit.y=0');
