Renumbering files
LCL999
Renumbering files
Post by LCL999 »
I have a number of files (Photos) in a folder which look like this:-
I want to replace the sequential number field (075, 076 etc) with a different one going up in increments of 5 or 10. Say 100, 110, 120, 130 etc.
How do I do it?
Note that the leading character field (12345_) is always the same length, and usually identical characters. (It's a date field I put in myself)
thanks
LCL
You could achieve that, but not in one step :
- add a new enumeration in front of the name (using "enumeration" action)
- remove the old sequential number (using "delete characters", if they always are the same length)
- move the new enumeration (using "move string")
steps 2 & 3 can be combined in one step using "regular expressions" action, though.
LCL999
Post by LCL999 »
That worked well. Like a little tutorial.
