remove duplicates
ismanpa
remove duplicates
Post by ismanpa »
Hello,
I have forgotten how to remove duplicates. I cannot see such a script. I use the latest AMC and have the script for duplicates.
Thank you!
That script is visible only through Tools->Scripting and not when opening the window to get info from sites (Movie->Get Info)
ismanpa
Post by ismanpa »
Thank you!
I was not notified about your reply even though I have ticked the option!
It is possible that it either does not work (I am not sure that I configured it correctly) or simply that your mail server does not like the e-mails sent by my web server (it seems to happen often with this hosting company).
davezn
Re: remove duplicates
Post by davezn »
I cannot see the script to remove duplicate titles.
Please could you advise?
Regards
Davezn
By the way BETA version working very well.
Over 5500 movies now in catalogue.
Regards
davezn wrote: 2018-06-07 12:32:05 I cannot see the script to remove duplicate titles.
Have you checked my post above, where I reply to the same question? :??:
davezn
Post by davezn »
Found the script, i had to show more langauges.
Ran the script and it created a TXT file.
Did not delete any movie duplicates.
Please could you explain whta I am doing wrong?
Regards
DaveZN
The script is just making a list, you have to do the cleaning manually afterwards.
davezn
Post by davezn »
Thank You.
