path field
pgouspy
path field
Post by pgouspy »
Hello,
Can you add a filed where we can set the path of the movies on disk ?
And make this field "clikable" to open the movies directly.
Thank You,
Pierre
The URL field does this. Click on the little arrow on the right side and use "Browse" to choose the movie file. Now you can use "Open URL" to play the movie instead of opening an URL.
pgouspy
Post by pgouspy »
hello,
I cannot find the "Open URL" button ....
It's in the same menu where you "Browse" for the movie, just click the little arrow at the end of the URL field.
pgouspy
Post by pgouspy »
Ok ! i'll find it.
What about un big button "play the film" for blind person like me :-)
