short cut
pgouspy
short cut
Post by pgouspy »
Hello,
Can you add the possibility to close the "scripté dialog by pressing escape key ?
Thank You,
PIerre
You mean the results window after retrieving movie information, I guess ? There's an option to not show this window after script execution. See frame "Execution options" on scripting window (upper right corner).
pgouspy
Post by pgouspy »
non, i speak the windows where you choose the script to use to retreive information
Ah, okay, that's in menu Tools > Preferences > Scripting > option "Auto-run last script used with 'Get information from script'". It will then supress the scripting dialog and runs the last/same script you used before.
He rather means closing the scripts list window at the end of the process.
There is a "close this window at the end" in the options of the script window (on the right)
