imdb.com has changed the whole website code (see also viewtopic.php?t=1735&postdays=0&postorder=asc&start=240).
So I had to rewrite the whole script.
Older versions are useless with latest website code.
I hope this version works a little longer than the last.
here is the new version 1.7.0
http://www.file-upload.net/download-288 ... 0.ifs.html
new ofdb-imdb (DE)
Raoul_Volfoni
Hi,Silrog wrote:It says that the file doesn't exist. Could you please reupload it? Or is there another update that I missed?
when a "script-author" send an update to antp, you can find this update here : http://update.antp.be/amc/scripts/
Or you can use the [Update_Scripts] script to update your scripts.
1.7.0 seems to be the latest version of Ofdb-Imdb (DE) script.
Tschüss *
* Only word i know in Deutsch ...
