[REQ] Extracting images from Kultvideo.it
Dear friends,
I'm writing a new script to extract informations from www.kultvideo.it, an Italian website specialized in B-movies.
I'm going to complete my work but I have problems in extracting images from the site. The url I use to extract the image is right, i'm sure, but the image is 'generated' dynamically, I think, by... I don't know what and how.
Would you help me to understand and to extract the image (use the movie 'django' to verify, you can see the web-address' image in audio format field.
Thanks in advance.
Authors=Fulvio53s03 based on original by Penanders (2006)
Title=Kultvideo
Description=Script per Kultvideo.it
Site=http://www.kultvideo.it
Language=IT
Version=2 - 2. 9.2010
Requires=3.5.1
Comments=Kultvideo offre poche informazioni, su film davvero introvabili
program KultVideo;
  StringUtils7552;
  MovieName, Pagestr: string;
  //TheMovieAddress: string;
  SITE = 'http://www.kultvideo.it/';
  SITE1 = 'http://www.kultvideo.it/';
//  SITE1 = 'http://www.kultvideo.it/scheda.asp';
//         http://www.kultvideo.it/articles/ArticleSheet.aspx?__langG=it-IT&aid=7244
//         ../articles/ArticleSheet.aspx?__langG=it-IT&aid=7244
// -- Formatta la stringa cercando le prime lettere rendendole maiuscole
function PrimeMaiu(str: string): string;
  str := AnsiLowerCase(str);
  str := AnsiMixedCase(str, ' -/');
  Result := str;
function Space2html(Url: string): string;
  Temp : string;
  SpacePos : Integer;
    SpacePos := pos(' ', Url);
    if SpacePos <> 0 then
        Temp := copy(Url, 1, SpacePos -1);
        Delete(Url, 1, SpacePos);
        Temp := Temp + '%20' + Url;
        Url := Temp;
  until pos(' ', Url) = 0;
  result := Url;
Function RemoveSpace(Line : String): String;
Var
Temp : String;
SpacePos : Integer;
Begin
  Repeat
  SpacePos := Pos('  ', line);
     If (Copy(Line, SpacePos, 2)) = '  ' then
     Delete(Line, SpacePos, 2);
  Until Pos('  ', Line) = 0;
If Pos(' ', Line) = 1 Then
Delete(line, 1, 1);
Result := Line;
End;
  LineNr: integer;
  BeginPos: integer;
  Pagestr := UTF8Decode(Page.Text);
  LineNr := FindLine('Risultati della ricerca per i termini', Page, 0);
    if LineNr = -1 then
    ShowError('Spiacente, nessun film trovato');
  else  // Trovati film ! Nota: possono esserci + pagine -> non ancora gestito !
    // Crea la lista di film
    PickTreeAdd('Risultati ricerca per "' + UrlDecode(MovieName) + '":', '');
    AddMoviesTitles(Page);
        Page.Text := GetPage(Address);  // Richiede la pagina del film
        Pagestr := Page.Text;
        SetField(FieldUrl, Address);
        //Page.savetofile('D:\Prova.txt');
        AnalyzeMoviePage(Page);         // Analizza la pagina del film
// Analisi ed estrazione dati dalla pagina del film
  //Fine: Integer;
  Line, Line2, Line3, Comm: string;
  InitChar, EndChar, SaveNationYear: string;
  BeginPos, EndPos: Integer;
  Field: integer;
  //Debug
  //Page.SaveToFile(PATHLOG+MovieName+'.film');
// data di estrazione dati
  // Immagine
  LineNr := FindLine('id="article_sheet_picture"', Page, 0);
  //showmessage(intToStr(LineNR));
  if LineNr>-1 then
    LineNr := LineNr + 1;
    Line := TextBetween(Line, '<img src="../', '" width="');
    if length(Line) > 0 then
        Line := SITE1 + Line;
        setfield(fieldAudioFormat, Line);
        GetPicture(Line);
  // Cerca il titolo tradotto
  LineNr := FindLine('<td id="article_sheet_title" align="left" valign="top"', Page, 0);
  Line := TextBetween(Line, '<td id="article_sheet_title" align="left"', '<') + '<';
  Line := TextBetween(Line, '>', '<');
  HTMLRemoveTags(Line);
  HTMLDecode(Line);
  Line := Fulltrim(Line);
  SetField(fieldTranslatedTitle, PrimeMaiu(Line) );
//    SetField(fieldOriginalTitle, PrimeMaiu(Line) );
  // Cerca il titolo originale
  InitChar := '<span class="article_sheet_filmsubtitle">';
  BeginPos := Pos(InitChar, Pagestr);
  Delete(Pagestr, 1, BeginPos - 1);
  EndChar := '<';
  LineNr := FindLine(InitChar, Page, 0);
  InitChar := '>';
  Line := InitChar + TextBetween(Line, '<span class="article_sheet_filmsubtitle">', EndChar) + EndChar;
  Line := TextBetween(Line, '>', EndChar);
  HTMLDecode(Line);
  Line := UTF8Decode(Line);
  // Cerca nazionalità e anno
  InitChar := '<td';
  EndChar :=  '</td>';
  Line := InitChar + Textbetween(Pagestr, InitChar, EndChar) + EndChar;
  HTMLDecode(Line);
  Line := Fulltrim(Line);  //'Francia (1987) - Colore'
  SaveNationYear := Line;
  Line := TextBefore(SaveNationYear, '(', '');
  SetField(fieldCountry, PrimeMaiu(Trim(Line)));
// esempio:  MovieName := TextBefore(MovieName, '[', '') + TextAfter(MovieName, ']');
  Line := TextBetween(SaveNationYear, '(', ')');
  SetField(fieldYear, Line);
  // Cerca genere
  InitChar := '<span class="article_sheet_datalabel">';
  Line := Textbetween(Pagestr, InitChar, '</td>');
  Delete(Pagestr, 1, BeginPos);
  Line := stringreplace(Line, 'Genere:', '');
  HTMLDecode(Line);
  SetField(fieldCategory, PrimeMaiu(Line));
  // Cerca regia
  Line := stringreplace(Line, 'Regia:', '');
  HTMLDecode(Line);
  SetField(fieldDirector, PrimeMaiu(Line));
  // Cerca cast
  Line := stringreplace(Line, 'Cast:', '');
  HTMLDecode(Line);
  SetField(fieldActors, PrimeMaiu(Line));
  comm := '';
  // Cerca distributore (al posto del produttore)
//  Line := stringreplace(Line, 'Cast:', '');
  HTMLDecode(Line);
  Line := stringreplace(Line, crlf, '');
  Line := stringreplace(Line, #09, '');
  Comm := Comm + Line + crlf;
//  Comm := Comm + Line + crlf;
  Delete(Pagestr, 1, BeginPos);  SetField(fieldComments, Comm);
  SetField(fieldDescription, Line);
  HTMLDecode(Line);
  // Cerca la durata
  Line := stringreplace(Line, 'Durata:', '');
  HTMLDecode(Line);
  SetField(fieldLength, Line);
// Riempie la lista con i film trovati
  Pagina: TStringList;
  //TheMovieAddress := '*';
  LineNr := 0;
    LineNr := FindLine('<div class="artlist_artpicture">', Page, LineNr);
  While LineNR <> -1 Do
  Begin
//  LineNr := 0;
  If LineNR = -1 Then Break;
  //Showmessage(intToStr(LineNr));
  // Crea l'url per la pagina completa del film
    //Showmessage(line);
    MovieAddress := TextBetween(Line, '<a href="../', '"><img src="');
    MovieAddress := SITE1 + MovieAddress;
    //ShowMessage(MovieAddress);
    Page.SetString(lineNR, ' ');
  //Estrazione Titolo film
    LineNr :=	FindLine('<td class="artlist_arttitle">', Page, LineNr);
    MovieTitle := Page.GetString(LineNr);
    //ShowMessage(MovieTitle);
    //Ripulisce il titolo
    HTMLRemoveTags(MovieTitle);
    HTMLDecode(MovieTitle);
    MovieTitle := Fulltrim(MovieTitle);
  // Controlla se ci sono altre pagine di risultati
  //LineNr := FindLine('Pagina Successiva',Page,0);
//  if LineNr<>-1 then
//    begin
//    idx := idx+1;
//    end;
    //Line := Page.GetString(LineNr);
    // Estrae l'URL della pagina successiva
    //BeginPos := pos('href="', Line)+5;
    //Delete( Line, 1, BeginPos);
    //BeginPos := 1;
    //EndPos := pos('"', Line);
    //Line := SITE1 + copy(Line, BeginPos, endPos-BeginPos);
    //ShowMessage(Line);
    // Richiama la pagina successiva e la analizza
    //Page.text := GetPage(Line);
    //Pagestr := Page.Text;
    // Debug
    //Page.SaveToFile(PATHLOG+MovieName+'.res'+IntToStr(idx));
    //Page.LoadFromFile(PATHLOG+MOVIE+'.res');
// ----- main()
Var
  TempVar: String;
  if CheckVersion(3,5,1) then
    MovieName := GetField(fieldtranslatedTitle);
    if Input('KultVideo.it', 'Inserire il nome del film:', MovieName) then
        MovieName := UrlEncode(MovieName);
//      TempVar:='http://www.kultvideo.it/cerca.asp?page=1&Genre=&key=&cerca='+UrlEncode(MovieName)+'&tipocerca=titolo&radiobutton=ALL';
        TempVar:='http://www.kultvideo.it/search/Search.aspx?st=' + MovieName;
        SetField(fieldURL, Tempvar);    // Memorizza il campo URL
        analyzepage(TempVar);
  ShowMessage('This script requires a newer version of Ant Movie Catalog (at least the version 3.5.1)');
The server requires that the "referer" is set to the same as the movie page.
GetPicture gives an empty referer (like if you copy/paste the link of the pic to a new window : it does not work either).
You have to use GetPicture2, and put the movie address as 2nd parameter
e.g.
GetPicture2(Line, GetField(fieldUrl));
This will work except if the user unchecked the "adress" field in the modifiable fields.
So to have this working in 100% of cases, you should keep the movie address either in a global variable, or pass it to the AnalyseMoviePage function, then pass it to GetPicture2.
I also see that there are accents problems in the various fields (title, actors, ...)
You'll have to use the UTF8Decode function for that
e.g.
PickTreeAdd(UTF8Decode(MovieTitle), MovieAddress);
PS: sorry for late answer, I could not check the forum this weekend
antp wrote:The server requires that the "referer" is set to the same as the movie page.
e.g.
GetPicture2(Line, GetField(fieldUrl));......
Thank You for your response, I knew to be moving my questions to the right guys :grinking:
I'm still working on the script and I saw errors you're saying, too.
I'll follow your suggestions and I hope to reach my aim.
Have a good week.
Fulvio.
P.S.
Verified, It's all OK.
Looking for informations about GetPicture2, I didn't find anything in AMC's Help.
Would you tell us something about it (and maybe other 'hidden' functions)?
thks.
It is in the help file, at least in the English & French file. Maybe you are using a translation for the help? (as I recall that some have been made, but were not updated)
Else check that you have the latest version of help file, from December 2009.
ok, FOUND, SORRY! :/
