[REQ] Old Script for MODS
Dear friends, I need to find an old script version of Allmusic.com as it looks to be have been in error just from the beginning.
Would you say to me where I could find it? (i.e. does a repository exist for those scripts? if not, would you create it?
Thanks in advance.
Re: [REQ] Old Script for MODS
fulvio53s03 wrote: does a repository exist for those scripts?
Not as far as I know.
I made a "Mods" section on the forum but never handled these mods. I focus on movie-related stuff since I already do not have much time for the program's original subject ;)
Uhm.. maybe viewtopic.php?t=3349 ?
Same for your releases, after a quick look they seem to be posted to the threads too, so it might be worth checking the old threads again. As there aren't so many in Mods it could be done easily.
bad4u wrote:Uhm.. maybe viewtopic.php?t=3349 ?
Thanks. I saw that thread... it was the reason why I thought the error in AllMusic's scripts (both of them) comes from the original script (rearranged from Allgames script): iit's easy to correct the script error (a simply field-name error) but, anyway, the script can be used in batch mode only after heavy modifications, i think.
At the moment I've no time to correct allMusic's script and I hope someone else could correct it.
I think, anyway, it could be a good Idea to have a repository with old scripts about AMC mods.
Have a good night, my friends.
:grinking:
