zip files
jofrog
zip files
Post by jofrog »
I have been reading the forum to inform myself before using the renamer. It sounds almost too easy! I have not seen anything about files needing to be unzipped or if it works within a zip file. Thanks in advance for your answer.
Jo
It does not handle archives so unfortunately you will need to extract files for renaming them.
The idea of renaming inside archives could be good though...
