Hi everyone,
I’m managing a website with a fairly large media library and want to clean up hundreds of image filenames using Ant Renamer.
Many files currently have generic names like IMG_1234.jpg or image-01.jpg. I’d like to batch rename them using a consistent structure based on their category or page while ensuring that duplicate filenames are not accidentally created.
What would be the best Ant Renamer setup for this? Is there a way to automatically handle duplicate names or append a number when the generated filename already exists?
Thanks for any guidance.
Best Way to Batch Rename Website Images Without Creating Duplicate Names?
jrsbailbond
- Location: 396 S Los Angeles St, Suite 208 Los Angeles, CA 90013 United States
Re: Best Way to Batch Rename Website Images Without Creating Duplicate Names?
Where are the info that you want to use as source?
I'm not sure that Ant Renamer would be the easiest solution for this.
If the images should be named using some metadata from a database (category or page as you suggested?), a custom script would be needed. Also, you would also need to update the links and not just rename the files, I suppose?
jrsbailbond
Thanks, that makes sense.
The source information would mainly come from the website structure. For example, I have images associated with different service/location pages, and I was thinking of using the page or category name as part of the filename.
My initial idea was to download the images, organize them into folders by page/category, and then use Ant Renamer to create consistent filenames within each folder.
You’re right about the links though. Renaming the files locally is straightforward, but replacing existing images on the website would also require updating their references.
Would Ant Renamer still be useful if I first organize the images into separate folders and only need it to generate consistent, unique filenames within each folder?
I'm not sure it would be the best solution anyway, since it does not have an option to add a counter in case there is duplicate name (except in some actions).
And since you'll lose the original file names and then you cannot update your links, I think a custom script would anyway be easier.
