[REL ITA] Filmup.it: new Release
A new Release of the Script that can extract both old-formatted and new-formatted pages.
Images extraction is OK, too.
Let me know problems you could enconter.
Authors=L. Francisco, Pivello, Zandal, Fulvio53s03
Title=FilmUP
Description=Get movie info from Leonardo.FilmUP.it and shows years in picklist (Fulvio53s03)
Site=http://filmup.leonardo.it
Language=IT
Version=1.0.6 - 11.08.2010
Requires=3.5.0
Comments=**Changes**|Pivello: query URL changed|Zandal:  sistemato puntamento a COMMENTS|Pivello: Film site URL selectable instead of FilmUp page
URL|dinolib: adapted to v.3.5.0 and little bugfix | ABNormal restarted...|14.04.2005: Fixed infinite loop if description field missing (Pivello)|16.09.2005:
Look for new Main Actors data into page; if present select this instead of Cast data (P)|16.09.2005: Added ActorPlusCast option (P)|03.10.2005 ABNormal: Big
Posters and Comments again|14.01.2006 ABNormal: Trailer URL| Adeguamento a nuove modalità di lista Film ed estrazione locandine
License=*  The source code of the script can be used in   |*  another program only if full credits to              |*  script author and a link to Ant Movie
Catalog  |*  website are given in the About box or in       |*  the documentation of the program               |
AlternateURL=0|0|0=Use the FilmUP web site for FieldURL|1=Try to use ufficial movie web site for FieldURL
MezzoVoto=1|1|0=Integer Ratings|1=Ratings with ,5
ActorsPlusCast=0|0|0=Get Main Actors data (if present) otherwise get Cast field|1=Get Main Actors data (if present) and Cast data
TrailerURL=0|0|0=Normal URL page|1=Trailer URL page (if found)
Poster=0|0|1=Download full-res Poster|0=Download tiny Poster
program LeonardoFilmUP;
  StringUtils1;
  MovieName, MovieToSearch, MovieTitle: string;
  TheMovieAddress, Pagestr: string;
  comm: String;
  LineNr: integer;
  BeginPos: integer;
  Pagestr := Getpage(Address);
  LineNr := FindLine('Ordina risultati per', Page, 0);
  if LineNr = -1 then
    AnalyzeMoviePage(Page);
    AddMoviesTitles;
    if TheMovieAddress='' then
      if PickTreeExec(Address) then AnalyzePage(Address);
//fulvio      SetField(fieldURL, TheMovieAddress);
  Line, PreviousLine, NomeHtml, sTemp: string;
  AddrImage: string;
  LineNr,PrevLineNr, BeginPos, EndPos, Field: Integer;
  IsMainActors: boolean;
  IsMainActors := false;
  sTemp := '';
  LineNr := FindLine('<font face="arial, helvetica" size="3"><b>', Page, 0);
  if LineNr > -1 then
    //Translated Title
    HTMLRemoveTags(Line);
      //Look for next info
        LineNr := LineNr + 1;
      until (Line<>'')  or (LineNr > Page.Count);
      // Test if 'Trama:' missing
      if ((PreviousLine = 'Data di uscita: ')
      or  (PreviousLine = 'Uscita prevista: ')) and (Line <> 'Trama:') then
        if (copy(Line,1,6)<>'Trama:') then
          Line := 'Trama:' + Line;
      PreviousLine := Line;
      //Look for type of line
      if Line = 'Titolo originale: ' then
        Field := fieldOriginalTitle
      else if Line = 'Regia: ' then
        Field := fieldDirector
      else if Line = 'Produzione: ' then
        Field := fieldProducer
      else if Line = 'Nazione: ' then
        Field := fieldCountry
      else if Line = 'Genere: ' then
        Field := fieldCategory
      else if Line = 'Anno: ' then
        Field := fieldYear
      else if Line = 'Durata: ' then
        Field := fieldLength //Special case: get number only
      else if Line = 'Sito ufficiale: ' then
        Field := fieldURL
      else if Line = 'Attori protagonisti: ' then
        Field := fieldActors;
        IsMainActors := true;
      else if Line = 'Cast: ' then
      else if Line = 'Trama:' then
        Field := fieldDescription
        Field := 0;
      // I have to add this test, for sometimes the description
      // is on the same line as the tag 'Trama'
      if (copy(Line,1,6)='Trama:') and (length(Line)>6) then
        Field := fieldDescription;
        Delete(Line,1,6);
        HTMLDecode(Line);
        //Get values
        HTMLDecode(Line);
        //Special case: Length
        if Field = fieldLength then Line := copy(Line,1,length(Line)-1);
       //Alternative URL case
       if (field = fieldURL) then
         if (Length(Line) = 0) or (GetOption('AlternateURL')=0) then      // if WEB url missing or explicitly requested...
           Line := GetField(fieldURL)  // ...restore FilmUp URL
           Line := 'http://'+Line;
      if Field<>0 then
       if Field = fieldActors then
         if IsMainActors then // Remember Main Actors (if present)
           sTemp := Line;
           if ((GetOption('ActorsPlusCast')=1) and (sTemp<>'')) then
             Line := sTemp + ' Cast: ' + Line
             if sTemp <> '' then
               Line := sTemp;
           SetField(Field,Line);
    until (Field=fieldDescription) or (LineNr > Page.Count);
  PrevLineNr := LineNr;
   //Trailer
if GetOption('TrailerURL')=1 then begin
LineNr := FindLine('">Trailer</a>', Page, PrevLineNr);
  if LineNr > -1 then
    if Pos('size="2"><a', Line) <> 0 then Delete(Line,1,pos('size="2"><a',Line));
    //if Pos('DVD', Line) <> 0 then Delete(Line,1,pos('DVD',Line));
    Delete(Line,1,pos('href="',Line)+5);
    NomeHtml := Copy(Line,1,pos('"',Line)-1);
    if (copy(NomeHtml,1,1)<>'/') then
      NomeHtml := '/' + NomeHtml;
NomeHtml :='http://filmup.leonardo.it' + NomeHtml;
    comm := textbetween(GetPage(NomeHtml),'<EMBED SRC="','"');
//HTMLRemoveTags(comm);
//Fulvio  SetField(fieldURL,comm);
  //Comments
  LineNr := FindLine('">Recensione</a>', Page, PrevLineNr);
  if LineNr > -1 then
    if Pos('Scheda', Line) <> 0 then Delete(Line,1,pos('Scheda',Line));
    NomeHtml :=Copy(Line,1,pos('"',Line)-1);
    comm := textbetween(GetPage(NomeHtml),'<font face="arial,helvetica" size="2"><b>','<a class="filmup" href="opinioni.htm">');
    comm := TextAfter(comm,'</b><br>'+#13#10);
    SetField(fieldComments,comm);
  //Rating
  LineNr := FindLine('">Opinioni</a>', Page, PrevLineNr);
  if LineNr > -1 then
    Delete(Line,1,pos('Recensione',Line));
    Line := GetLineFromOtherPage(Copy(Line,1,pos('"',Line)-1),'</b> - <img src="');
    if Line <> '' then
      Line := Copy(Line,1,pos('</b> - <img src="',Line)-1);
      if GetOption('MezzoVoto')=0 then
 if pos('.',Line)>0 then Line := Copy(Line,1,pos('.',Line)-1);
      SetField(fieldRating,Line);
  //Picture // start fulvio53s03 Code
    LineNr := FindLine('<img src="locand/', Page, PrevLineNr);
  if LineNr > -1 then
      AddrImage := TextBetween(Line, '<img src="', '" width="');
      AddrImage := 'http://filmup.leonardo.it/' + AddrImage;
      GetPicture(AddrImage);
  if GetOption('Poster')=1 then
    LineNr := FindLine('href="posters/locp/', Page, PrevLineNr);  //cerca Poster grande
    if LineNr > -1 then
      AddrImage := TextBetween(Line, 'href="posters/locp/', '" target="_blank"');
      AddrImage := 'http://filmup.leonardo.it/posters/loc/500/' + AddrImage;
      AddrImage := StringReplace(AddrImage, '.htm', '.jpg');
//      http://filmup.leonardo.it/posters/locp/toystory2.htm
//      http://filmup.leonardo.it/posters/loc/500/toystory2.jpg
//      Line := GetLineFromOtherPage('http://filmup.leonardo.it/'+Copy(Line,1,pos('"',Line)-1),'<img src="../loc/500/');
//      if Line <> '' then
//      begin
//        Delete(Line,1,pos('<img src="../',Line)+12);
//        GetPicture('http://filmup.leonardo.it/posters/'+Copy(Line,1,pos('"',Line)-1));
//      end;
function GetLineFromOtherPage(address: string; hint: string): string;
  LineNr: integer;
  LineNr := FindLine(hint, Page, 0);
  if LineNr > -1 then result := Page.GetString(LineNr);
procedure GetComments(address: string);
  BeginLine: integer;
  EndLine: integer;
  i: integer;
  Line, Comments: string;
  BeginLine := FindLine('RECENSIONI', Page, 0);
  BeginLine := FindLine('<font face="arial,helvetica" size="2"><b>', Page, BeginLine);
  EndLine := FindLine('<a href="opinioni.htm">Scrivi la tua recensione!</a></font><br><br>', Page, BeginLine);
  for i:= BeginLine+1 to EndLine-1 do
    Line := Page.GetString(i);
    Line := StringReplace(Line, '<br>', #13#10);
    Line := StringReplace(Line, #13#10#32, #13#10);
    HTMLDecode(Line);
    Comments := Comments + Line;
function MyTrim(Value: string):string;
  ExitLoop: Boolean;
  NewField, OldField: String;
  OldLgthValue, NewLgthValue: integer;
    NewField := ' ';
    OldField := #9;
    value := StringReplace(Value, OldField, NewField);
    OldField := #10;
    OldField := #13;
    OldField := '  ';
    Newfield := '&';
    OldField := '&';
    ExitLoop := False;
    OldLgthValue := length(Value);
      NewLgthValue := length(Value);
    if  OldLgthValue = NewLgthValue then
        ExitLoop := True
        OldLgthValue := NewLgthValue;
    until ExitLoop;
  Result := '';
  HTMLRemoveTags(Value);
  Result := Value;
procedure AddMoviesTitles;
  LineNr, CharToDelete: Integer;
  Line, Blocco: string;
  MovieAddress, MovieAnno: string;
  BeginPos, EndPos: Integer;
//fulvio  LineNr := FindLine('FilmUP - Scheda: ',Page,LineNr);
    Pagestr := '<DL>' + Textbetween(Pagestr, '<DL>', 'Risultati della ricerca:<br>');     //estrae tabella dei risultati
    Blocco := Textbetween(Pagestr, '<DL>', '</DL>');         //estrae elemento della tabella
    CharToDelete := Length(Blocco) + 9;    //lgth dati estratti + lgth delimiters estrazione
  while CharToDelete > 9 do
    MovieAddress := TextBetween(Blocco, '<a class="filmup" href="', '" TARGET="_blank">');
    MovieTitle := '<span' + TextBetween(Blocco, '<span', '</a>') + '</a>';
    MovieTitle := Mytrim(MovieTitle);
//    HTMLRemoveTags(MovieTitle);
//    HTMLDecode(Movietitle);
  MovieAnno := TextBetween(Blocco, 'Anno: ', ' Genere');
  MovieTitle := MovieTitle + ' [' + MovieAnno + ']';
  MovieTitle := StringReplace(MovieTitle, 'FilmUP - Scheda: ', '');
  MovieTitle := StringReplace(MovieTitle, ' / FilmUP.com ', '');
  If Length(MovieAnno) > 0 then
  if TheMovieAddress='*' then
     TheMovieAddress := MovieAddress
     TheMovieAddress := '';
    delete(Pagestr, 1, CharTodelete)
//    delete(Pagestr, 1, CharTodelete)
//  end;
//Fulvio  LineNr := FindLine('Successivo',Page,LineNr);
//Fulvio  Line := Page.GetString(LineNr);
//Fulvio  BeginPos := pos('HREF',Line);
//Fulvio  if BeginPos>0 then
//Fulvio  begin
//Fulvio    Delete(Line,1,BeginPos + 5);
//Fulvio    EndPos := pos('"',Line);
//Fulvio    MovieAddress := copy(Line,1,EndPos-1);
//Fulvio    PickTreeMoreLink(MovieAddress);
//Fulvio  end;
// Questo è il main dello script
  if CheckVersion(3,5,0) then
    TheMovieAddress := '*';
    MovieName := StringReplace(GetField(fieldTranslatedTitle), '.', ' ');
While pos ('[', MovieName) > 0 Do begin
  MovieName := TextBefore(MovieName, '[', '') + TextAfter(MovieName, ']');
    if Input('FilmUP Import', 'Digita il titolo del film:', MovieName) then
    MovieToSearch:=StringReplace(MovieName, ' ', '+');
//Fulvio  ricerca per 'Termini contenuti':
// &ul=%25%2Fsc_%25&x=60&y=11&m=all&wf=0020&wm=sub&sy=0
    AnalyzePage('http://filmup.leonardo.it/cgi-bin/search.cgi?ps=100&fmt=long&q='+MovieToSearch+'&ul=%25%2Fsc_%25&x=60&y=11&m=all&wf=0020&wm=sub&sy=0');
//Fulvio  ricerca per 'Termini esatti':
//    AnalyzePage('http://filmup.leonardo.it/cgi-bin/search.cgi?ps=100&fmt=long&q='+MovieToSearch+'&ul=%25%2Fsc_%25&x=31&y=12&m=all&wf=0020&wm=wrd&sy=0');
    ShowMessage('Questo script richiede una versione più nuova di Ant Movie Catalog (almeno la versione 3.5.0)');
From which version did you start? The current one had a version number of 1.0.5 :??:
Sorry, Maybe my starting version was not the last one but, any way, this one is going well....
I hope someone else could verify it, I looked on more than 15 movies and my new version is OK... :ha:
P.S.
I found a way to verify differences from the version I used (1.02) and the Last one (1.05) (using superc of SPFPC).
All differences are now updated and/or renewed in this new version.
I change the version in 1.06 (instead of 1.03) and now, I think, it's all OK.
Bye and thanks for your attention (I'm always the solito pasticcione) :ha:
Thanks for your work :)
DjDiabolik
Post by DjDiabolik »
Fulvio are great :)
Now appears to working all :)
I have try to found the difference between version 1.0.5 but it's not simple especially when you do not know the language of script.
I have try to found on internet some information about how make a new script but i have not found nothing :(
DjDiabolik
I have downloaded the news script from the updated script but now i can see it with other script...
Come dicevo dall'altra parte... ora non compare + nella lista tra gli altri script... perchè ?
DjDiabolik wrote:I have downloaded the news script from the updated script but now i can see it with other script...
What do you mean?
please, give us more details
Da dove l'hai scaricato?
non compare più? in quale lista? quella caricata con f6?
Che significa? per cortesia, fornisci maggiori dettagli.
As I said on the other topic, it is my fault: there was an empty line at the top of the script why I copy/pasted it from here.
I re-uploaded it on the server.
DjDiabolik
Posted problems in PM.
Now the script appear on the list... but i obtain error in line 3.
unit it's not found linea 3 .
*EDIT*
I have the same error with others script! Azz...
*EDIT 2*
Resolved with a Full reinstallation :)
Your file 'stringutils1.pas' was probably missing/damaged/outdated?
DjDiabolik
antp wrote:Your file 'stringutils1.pas' was probably missing/damaged/outdated?
No.. i have deleted it... i'm wrong.
Full working after reinstalling all programs :)
otreux
Post by otreux »
don't work correctly, it import the thumbnail but not the bigger pic.
Non funziona correttamente, importa la foto piccola e non quella grande
otreux wrote:don't work correctly, it import the thumbnail but not the bigger pic.
Fornisci ulteriori informnazioni, per cortesia: con quale film?
More informations, plese: which Movie?
otreux
Post by otreux »
Sicuro che stai usando lo script con l'opzione 'Poster = 1' ? ;) :??:
Il default è 0 (piccolo poster) ma basta cambiarlo... :hihi:
otreux
Post by otreux »
Nello script io ho
In the script I have:
Cosa devo cambiare?
What I must change?
otreux wrote: Poster=0|0|1=Download full-res Poster|0=Download tiny Poster
puoi cambiare in:
Poster=1|0|1=Download full-res Poster|0=Download tiny Poster
ma non è questo il metodo giusto: devi guardare nella parte desta della pagina di esecuzione degli script e li' modificare l'opzione di esecuzione.
ciao.
otreux
Post by otreux »
Fantastico, non avevo vista questa opzione.
Fantastic, It work perfectly, many thank's :)
Nobody72
Post by Nobody72 »
Ciao Fulvio. grazie per tutto. Il mio script di filmup continua ad estrarre l'immagine con pessima risoluzione. non so cosa fare. Se puoi dammi una mano. ciao
Nobody72
Post by Nobody72 »
Riciao Fulvio! finalmente ho capito cosa non andava. mi è bastato cambiare l'1 con lo 0 nello script del poster ed ora l'immagine viene scaricata in formato più grande. Nello script c'è l'1 ..io ho messo lo zero ed ora funziona. Spero di essermi spiegato. ciao
