Disappearing Predefined sets?
bjornkn
Post by bjornkn »
I have been using this wonderful program for a while now, and it's a true gem. Saves a lot of time :-)
I use the Multiple string replacement command a lot, writing shortcuts in the filenames which are then translated to the full word.
I have som long sets named like rydd1 to rydd6. I also made a set named rydd7.
For some odd reason the rydd7 disappeared from the list of sets, unfortunately.
But what is strange is that I used rydd7 in a saved batch (before it disappeared) - and it still works. !
Apparently the rydd7 must be available somewhere, but how can I get access to it , and use it?
Where are those sets saved, and can they be manually edited?
Re: Disappearing Predefined sets?
Indeed, the whole set to use is stored in the batch.
There is no direct way to import it with the program, but if you open the .arb (batch) file in a text editor and select all the lines of your set (between <![CDATA[ and ]]>, the first line being directly after the start tag) you can easily import the list in a new set by clicking the "Paste/Import" button.
bjornkn
Post by bjornkn »
Thank you :-)
bjornkn
Post by bjornkn »
A little followup..
I often save a lot of sets, but very often after I save them they're not available the next time I run AntRenamer.
Any idea why, and ways to avoid it?
Also I often add or change lines to a set. The next time with AntRenamer they have sometimes disappeared.
I can't see why thie happens?
Appearently all such sets are stored in the Renamer.xml file.
Would it be a solution to edit that file directly?
Or are there other ways to avoid those problems?
That's strange, there could be issues if you have multiple instances of Ant Renamer running at the same time: only the data known by the last one you close is saved, overwriting what others wrote before.
But if you have one window open at a time, I don't know why it would sometimes save and sometimes not :??:
You can also directly edit the file, using a text editor.
If you use Notepad++ I think it warns you in case the XML is made invalid by an edit, but for security it is good to make a copy of it before doing changes.
