import a list of film with the same number
pty99
Post by pty99 »
i want import multiple files and give to them the same number or, it's the same result, i want to change the number of multiple entries and give to them the same number. sorry for my poor english
I do not really understand your question :??: What is the problem exactly?
pty99
Post by pty99 »
It's difficult for me, please be patient. For example i want import ten shows. Normally antmovie give to them numbers 1-10 ok i don't want this i want every singol show to have number 1. In this way i have ten shows that have number 1. I use IMtoAMC to import a series of shows through the function IMPORT from menu FILE. Antmovie give to them sequential numbers and i don't want this i want only one number.
If you have already the number in one of the columns of the file that you import, you can enable the option to allow duplicate numbers and directly set numbers at importation.
pty99
Post by pty99 »
ok problem solved, thanks. I edited the csv file generated by IMtoAMC
