cant export to html anymore
Mj
Post by Mj »
i exported to html once...then deleted those exported files...now i cant export to html anymore...it only exports a blank html file
is there still something in the HTML template area of export window ?
if no, open a template in the export window.
If you deleted the templates you can get them back by reinstalling the program or downloading the file amc_templates.zip from my site.
Mj
Post by Mj »
thanks, i guess i deleted the templates...i reinstalled and it works fine now
M.
