Hi everyone!
I'm trying to export all my movies, but it is impossible because my "catalogs" folder happens to be empty. I don't get it!! When I load my catalogs and movies, they all show in and I can modify them, save them, etc.
Can someone help me?
PS: I have Windows Vista and Ant Movie Catalog 3.5.1
Thanks a lot!
My "Catalogs" folder is empty!!
Hi.
If I remember correct, Vista uses a virtual store folder like Win7 does. It protects the program folders and saves all files, that programs try to write to their own installation folder, to a hidden folder named "Virtual Store". On Win7 it can be found on c:\user\username\AppData\Local\VirtualStore , I think it was a similar path for Vista.
But you can simply open your catalog and save it to another folder on your harddisk, preferably a folder in your own documents.
