AntMovie Catalog to XML UTF-8
volvodriver
Post by volvodriver »
Hello,
This is probably a really straightforward thing but I can't work it out for the life of me.
I recently purchased HD Movies on the iPad and wish to import my Ant Movie catalog into it.
The developers of HD Movies supplies a website where you can upload an XML and it will be converted into a usable file for the iPad app. (http://www.netwalkapps.com/python/convert2movies.html)
The XML must be in UTF-8. However I cannot see any option in Ant Movie Catalog to export to XML with different encoding. I always get '<?xml version="1.0" encoding="iso-8859-1"?>'
I am using the latest downloadable AMC, am I missing a script or another prerequisite?
Thanks for any help.
This issue has been discussed on this thread. AMC does not support Unicode and HD Movies converter does not catch these cases (as long as AMC can't export/save to UTF-8 encoded XML, you need to handle this in your import routines).
