[UPD][EN] MyAnimeList v1.2
FinderX
Post by FinderX »
MyAnimeList v1.2:
  • FIX: Text coded with HTML numbers, like &#123456 ; (without the space)
    FIX: Applied simple patch to UTF8Decode
    FIX: In BatchMode only search the first page of results
    CHANGE: The percent rate is stored until one satifies the setting percent
    CHANGE: StringUtils7552 to StringUtils1
    CHANGE: CompareWords to CompareText
    CHANGE: uses UNIT for this script -> MyAnimeListUtils.pas
    ADD: "Set % Once" option
    ADD: "At Least One" option
    ADD: "ALT_TITLE_SEPARATOR" const
    ADD: "INFO_START_TAG" const
    ADD: "INFO_END_TAG" const
    ADD: "BLANK_FOR_QUERY" const
    ADD: "HTML_CODES" const (in MyAnimeListUtils.pas)
Hi, i again,
I hope this is be the last version to this page because i'm too tired :zzz:
the truth is that page is a nightmare! mixed charset and uni-codes and html codes and go on...
OK, first of all: In BatchMode, i changed the find method from "first hit" to "best rate" of percent stored. Is still search until one is more great (or equal) of percentage seted, but not ALL the results, is per page. No unnecessary connections.
The function CompareWords of StringUtils7552 is interesting, but not very accurate in differentiating a result of another. That is why i changed to CompareText (home made) that compare by text blocks.
From StringUtils7552 just used one function (CompareWords), so the cameback to StringUtils1. And the code is become fatter and fatter, i had to separate it into a unit (library?) and the main script.
Now the options:
  • Set % Once : You can set the percentage for one batch session , not default value. If this option actived, only one window appaer in whole batch.
    At Least One : This option use the best rate result stored if no one satified the seted percent.
Now the editor const:
  • ALT_TITLE_SEPARATOR : this format the separator of translated titles, if you not like ', ' here you can set your favorite, for example
    • ' | ' = 'title1 | title2 | title3'
      ' - ' = 'title1 - title2 - title3'
      ' ~ ' = 'title1 ~ title2 ~ title3'
      also
      '<br>' = 'title1<br>title2<br>title3' this is useful for html exports
    INFO_START_TAG and INFO_END_TAG : the same idea for ALT_TITLE_SEPARATOR if you don't like my style, use yours ;)
    example:
    IST='[' IET=']'
    • [Related Anime]
      [Opening Theme]
    IST='~' IET='~'
    • ~Related Anime~
      ~Opening Theme~
    IST='¡¡¡¿' IET='?!!!'
    • ¡¡¡¿Related Anime?!!!
      ¡¡¡¿Opening Theme?!!!
    also the text plain :p
    IST='' IET=':'
    • Related Anime:
      Opening Theme:
    BLANK_FOR_QUERY : This is Important. Here you can add (or remove) chars that, in the query of the site and comparison of the results, are to will removed for better results.
    HTML_CODES : If in the future appear more codes to decode, here you can add the new ones.
Is all...
PD: I remeber you that I use :google translator from my lang to you :)
FinderX
Post by FinderX »
---------------------------------------MyAnimeListUtils.pas---------------------------------------
unit MyAnimeListUtils;
uses StringUtils1;
    HTML_CODES =  '…=…,' + '«=«,'  + '»=»,' + '‹=‹,' +
                  '”=”,'  + '‚=,,'  + '„=„,' + '&apos;='','  +
function GetMovieName(Separator:string) : string;
    result := GetField(fieldOriginalTitle);
    if (result = '') then begin
        result := GetField(fieldTranslatedTitle);
        if (Separator <> '') and (Pos(Separator,result) > 0 ) then
        result := TextBefore(result,Separator,'');
procedure SortDescending(List:TStringList ; StartAt,EndAt:Integer);
    str1, str2: string;
    if (EndAt <= StartAt) then EXIT;
    str1 := List.GetString(StartAt);
    str2 := List.GetString(StartAt + 1);
    if (Length(str1) < Length(str2)) then begin
        List.SetString(StartAt + 1,str1);
        List.SetString(StartAt,str2);
    SortDescending(List,StartAt + 1,EndAt);
function ValidatePercent(Value:string) : Boolean;
    i, num: Integer;
    ch: string;
    result := False;
    for i := 1 to Length(Value) do begin
        ch := Copy(Value,i,1);
        if (Pos(ch,'0123456789') = 0) then EXIT;
    num := StrToInt(Value,0);
    if (num >= 0) and (num <= 100)
        then result := TRUE;
function CompareText(Str1, Str2: string) :integer;
    list1, list2: TStringList;
    i, lineNr, charsMatch, totalChars:Integer;
    if (Str1 = '') and (Str2 = '') then begin
        result := 100;
        EXIT;
    end;        // Only case that provoke division by zero
    if (Str1 = '') or (Str2 = '') then begin
        result := 0;
        EXIT;
    end;        // For performance only
    list1 := TStringList.Create;
    list2 := TStringList.Create;
    list1.Text := StringReplace(Str1,' ',#13#10);
    list2.Text := StringReplace(Str2,' ',#13#10);
    for i := 1 to list1.Count do
        SortDescending(list1,0,list1.Count - i);
    for i := 1 to list2.Count do
        SortDescending(list2,0,list2.Count - i);
    for i := 0 to (list1.Count - 1) do begin
        lineNr := FindLine(list1.GetString(i),list2,0);
        if (lineNr > -1) then begin
            charsMatch := charsMatch + Length(list1.GetString(i));
            Str1 := StringReplace(Str1,list1.GetString(i),'');
            list2.SetString(lineNr,#2);
        if (StringReplace(list2.Text,#2#13#10,'') = '') then Break;
    list1.Free;
    list2.Free;
    totalChars := Length(StringReplace(Str2,' ','')) + Length(StringReplace(Str1,' ',''));
    result := (charsMatch * 100) div totalChars;
function BlankAndCompact(Str:string ; CharsToBlank:string) : string;
    ch: string;
    atPos: Integer;
    result := '';
    for atPos := 1 to Length(Str) do begin
        ch := Copy(Str,atPos,1);
        if (Pos(ch,CharsToBlank) > 0) then
            ch := ' ';
        result := result + ch;
    while (Pos('  ',result) > 0) do
        result := StringReplace(result,'  ',' ');
    result := Trim(result);
function RemoveNonAnsiHtmlNum(Str:string) : string;
    text, htmlNum, htmlCode: string;
    htmlNum := TextBetween(Str,'&#',';');
    if (htmlNum <> '') then
        text := Copy(Str,1,Length(Str));
    while (htmlNum <> '') do begin
        htmlCode := '&#' + htmlNum + ';';
        if (StrToInt(htmlNum,0) > 255) then
            Str := StringReplace(Str,htmlCode,'?');
        text := StringReplace(text,htmlCode,'');
        htmlNum := TextBetween(text,'&#',';');
    result := Str;
function HTMLDecodePatch(Str:string ; CodeTable:string) : string;
    table: TStringList;
    code, decode: string;
    table := TStringList.Create;
    table.CommaText := CodeTable;
    for i := 0 to (table.Count - 1) do begin
        code := table.GetName(i);
        decode := TextAfter(table.GetString(i),'=');
        Str := StringReplace(Str,code,decode);
    table.Free;
    result := Str;
function funcHTMLDecode(Str:string) : string;
    Str := HTMLDecodePatch(Str,HTML_CODES);
    Str := RemoveNonAnsiHtmlNum(Str);
    HTMLDecode(Str);
    result := Str;
function funcUTF8Decode(Str:string) : string;
    result := UTF8Decode(Str);
    if (result = '') then result := Str;
function funcHTMLRemoveTags(Str:string) : string;
    HTMLRemoveTags(Str);
    result := Str;
function ParserText(Text:string ; StartAt:string ; EndAt:string) : string;
    result :=
        FullTrim(
            funcHTMLDecode(
                funcUTF8Decode(
                    funcHTMLRemoveTags(
                        TextBetween(Text,StartAt,EndAt)
FinderX
Post by FinderX »
---------------------------------------MyAnimeList.ifs---------------------------------------
Authors=FinderX
Title=MyAnimeList
Description=Script for anime information in MyAnimeList.net
Site=http://myanimelist.net/
Language=EN-Anime
Version=1.2 @ 2010-06-05
Requires=3.5.1
Comments=In EDITOR MODE there're more options||DEFAULT_PERCENT            USER_CHAR_SEPARATOR      USER_SEPARATOR_LENGTH|ALT_TITLE_SEPARATOR     INFO_START_TAG                  INFO_END_TAG
Batch Mode=0|0|0=No : Normal Mode|1=Yes : Batch Mode
Set % Once=0|0|0=No : Percent Default Value |1=Yes : Set Percent for the batch, not default
At Least One=0|0|0=No : No result if none comes to Percent|1=Yes : If none comes to Percent, then the best rate
Reviews=1|0|0=Simple : First two from Details Page|1=Full : All from Reviews Page if has more of two
Picture=1|0|0=Small : Thumbnail from Details Page|1=Big : Fullsize from 'pic&pid' Page, if exists or else thumbnail
program MyAnimeList;
uses MyAnimeListUtils;
    DEFAULT_PERCENT = 100;            // BatchMode Percentage Title, 100 = title perfect match
    USER_CHAR_SEPARATOR = '_';        // Char separator between users in Comments
    USER_SEPARATOR_LENGTH = 120;      // Separator length between users in Comments
    ALT_TITLE_SEPARATOR = ', ';       // Here set your alternative titles separator
    INFO_START_TAG = '[';             // Additional Info start tag title section
    INFO_END_TAG = ']';               // Additional Info end tag title section
    BLANK_FOR_QUERY = ':;-·†_–%—''|`´~.';    // More accurate results without these characters
    MY_ANIME_LIST_QUERY = 'http://myanimelist.net/anime.php?q=';
    MY_ANIME_LIST_ADDRESS = 'http://myanimelist.net/anime/';
    FIND_MORE = 'Find More';
    MovieName, BM_BestResultAddress: string;
    BatchMode, FullReviews, BigPicture: Boolean;
    BM_MatchFind, BM_SetedPercentOnce: Boolean;
    ExitNormalMode, SetPercent: Boolean;
    CancelBatch, AtLeastOne: Boolean;
    NumResults, BM_Percent:Integer;
    BM_BestResultPercent: Integer;
procedure SettingPercentOnce;
    acceptValue: Boolean;
    inputPercent:string;
    if BM_SetedPercentOnce then EXIT;
    BM_SetedPercentOnce := TRUE;
    BM_Percent := DEFAULT_PERCENT;
    inputPercent := IntToStr(BM_Percent);
    acceptValue := FALSE;
        if (Input('Setting Percent','Percent [0 to 100]:',inputPercent) = FALSE) then begin
            CancelBatch := TRUE;
            EXIT;
        acceptValue := ValidatePercent(inputPercent);
        if not acceptValue then
            ShowError('The value "' + inputPercent + '" is not valid');
    until acceptValue;
procedure ExecutePickTree(var Address:string);
    if BatchMode then EXIT;
    if (NumResults > 0) then begin
        if PickTreeExec(Address) then begin
            if (Address <> FIND_MORE) then begin
                AnalyzeMoviePage(Address);
                ExitNormalMode := TRUE;
        end else begin
            Address := ''; // Cancel Button
        ShowInformation('No results found for "' + MovieName +
                        '"' + #13#10 + 'Try another title');
procedure AnalyzeForVariuosPages(Name:string);
    address, nextAddress, addressPage: string;
    strPage, titleTag: string;
    pagePos, page, totalPages: integer;
    titleTag := '<title>Anime - MyAnimeList.net</title>';
    address := MY_ANIME_LIST_QUERY + UrlEncode(BlankAndCompact(Name,BLANK_FOR_QUERY));
    strPage := GetPage(address);
    address := FIND_MORE;
    pagePos := Pos('Pages (',strPage);
    if (pagePos > 0 ) then begin
        addressPage := TextBetween(strPage,'Pages','</div>');
        totalPages := StrToInt(TextBetween(addressPage,'(',')'),0);
        for page := 1 to totalPages do begin
            PickTreeAdd('MyAnimeList - Page ' + IntToStr(page) + ' of ' + IntToStr(totalPages),'');
            AnalyzePage(strPage);
            if (page < totalPages) then PickTreeMoreLink(FIND_MORE);
            ExecutePickTree(address);
            if BM_MatchFind or (address <> FIND_MORE)
                then Break;
            if (page < totalPages) then begin
                nextAddress := TextBetween(addressPage,'[' + IntToStr(page) + '] <a href="?q=','>');
                nextAddress := MY_ANIME_LIST_QUERY + nextAddress;
                strPage := GetPage(UrlEncode(nextAddress));
    end else begin
        if (Pos(titleTag,strPage) > 0) then begin
            PickTreeAdd('MyAnimeList','');
        end else begin
            AnalyzeMoviePage(strPage);
    if BatchMode and AtLeastOne then
        if (BM_MatchFind = FALSE) and (BM_BestResultAddress <> '') then
            AnalyzeMoviePage(BM_BestResultAddress);
procedure AnalyzePage(PageStr:string);
    movieAddr, movieTitle, movieID: string;
    titleTag, title, compTitle, compName: string;
    titlePos, titleLine, compare: Integer;
    strPage: TStringList;
    strPage := TStringList.Create;
    strPage.Text := PageStr;
    titleTag := '<a href="' + MY_ANIME_LIST_ADDRESS;
    titleLine := FindLine(titleTag,strPage,0);
    while (titleLine > -1) do begin
        title := strPage.GetString(titleLine);
        titlePos := Pos('<strong>',title);
            if (titlePos > 0) then begin
                movieId := TextBetween(title,titleTag,'/');
                movieAddr := MY_ANIME_LIST_ADDRESS + MovieId;
                movieTitle := ParserText(title,'<strong>','</strong>');
                if BatchMode then begin
                    compTitle := BlankAndCompact(movieTitle,BLANK_FOR_QUERY);
                    compName := BlankAndCompact(MovieName,BLANK_FOR_QUERY);
                    compare := CompareText(AnsiLowerCase(compName),AnsiLowerCase(compTitle));
                    if (compare > BM_BestResultPercent) then begin
                        BM_BestResultPercent := compare;
                        BM_BestResultAddress := movieAddr;
                PickTreeAdd(movieTitle,movieAddr);
                NumResults := NumResults + 1;
        titleLine := FindLine(titleTag,strPage,titleLine + 1);
        if (BM_Percent <= BM_BestResultPercent) then begin
            BM_MatchFind := TRUE;
    strPage.Free;
procedure AnalyzeMoviePage(Address:string);
    page: TStringList;
    lineNr, lineAux, revLine, numRev: integer;
    fansub, info, group, user, review, reviews: string;
    reviewsAddress, pictureAddress, altTitle: string;
    pictureTag, indexTag, userTag, groupTag: string;
    item, thumbPicture, separator: string;
    fansub := '<a href="http://myanimelist.net/fansub-groups.php?id=';
    thumbPicture := 'http://cdn.myanimelist.net/images/anime/';
    pictureTag := '<a href="' + MY_ANIME_LIST_ADDRESS;
    indexTag := '<a  href="' + MY_ANIME_LIST_ADDRESS; // the doble space is important
    userTag := '<a href="http://myanimelist.net/profile/';
    page := TStringList.Create;
    // URL
    item := Copy(Address,1,Length('http://'));
    if (Pos('http://',item) = 1) then begin
        page.Text := GetPage(Address);
        SetField(fieldURL,Address);
    end else begin
        page.Text := Address;
        lineNr := FindLine(MY_ANIME_LIST_ADDRESS,page,0);
        item := MY_ANIME_LIST_ADDRESS + TextBetween(page.GetString(lineNr),MY_ANIME_LIST_ADDRESS,'/');
        SetField(fieldURL,item);
    // Original Title - Title
    lineNr := FindLine('<title>',page,0);
    SetField(fieldOriginalTitle,ParserText(page.GetString(lineNr),'<title>',' - MyAnimeList.net</title>'));
    // Picture Address
    lineNr := FindLine('pic&pid',page,lineNr);
    if (lineNr > -1) and BigPicture then
        pictureAddress := MY_ANIME_LIST_ADDRESS + TextBetween(page.GetString(lineNr),pictureTag,'">')
    else begin
        lineNr := FindLine(thumbPicture,page,0);
        pictureAddress := thumbPicture + TextBetween(page.GetString(lineNr),thumbPicture,'" alt="');
    // TranslatedTitle - Alternative Title(s)
    lineNr := FindLine('Alternative Titles',page,lineNr);
    altTitle := ParserText(page.GetString(lineNr),'English:','</div>');
    item := ParserText(page.GetString(lineNr),'Synonyms:','</div>');
    if (item <> '') then begin
        item := StringReplace(item,', ',ALT_TITLE_SEPARATOR);
        if (altTitle <> '') then altTitle := altTitle + ALT_TITLE_SEPARATOR;
        altTitle := altTitle + item;
    item := ParserText(page.GetString(lineNr),'Japanese:','</div>');
    SetField(fieldTranslatedTitle,altTitle);
    // Director - Type
    lineNr := FindLine('Type:',page,lineNr);
    SetField(fieldDirector,ParserText(page.GetString(lineNr),'Type:','</div>'));
    // Disks - Episodies
    lineNr := FindLine('Episodes:',page,lineNr);
    item := page.GetString(lineNr) + #2;
    SetField(fieldDisks,ParserText(item,'Episodes:',#2));
    // Year - Year of start aired only
    lineNr := FindLine('Aired:',page,lineNr);
    item := Copy(TextAfter(page.GetString(lineNr),', '),1,4);
    SetField(fieldYear,item);
    // Productor - Studio
    lineNr := FindLine('Producers:',page,lineNr);
    item := page.GetString(lineNr) + page.GetString(lineNr + 1);
    if (Pos('None found',item) = 0)
        then item := ParserText(item,'Producers:','</div>')
        else item := '';
    SetField(fieldProducer,item);
    // Source - Genres
    lineNr := FindLine('Genres:',page,lineNr);
    item := AnsiMixedCase(ParserText(item,'Genres:','</div>'),' ,-');
    SetField(fieldSource,StringReplace(item,' Of ',' of '));
    // Reviews Address
    lineNr := FindLine(indexTag,page,lineNr);
    while (Pos('Reviews',page.GetString(LineNr)) = 0) do
        lineNr := FindLine(indexTag,page,lineNr + 1);
    reviewsAddress := MY_ANIME_LIST_ADDRESS + TextBetween(page.GetString(lineNr),indexTag,'">');
    // Description - Synopsis
    lineNr := FindLine('<h2>Synopsis</h2>',page,lineNr);
    item := page.GetString(lineNr);
    while (Pos('</td>',item) = 0) do begin
        lineNr := lineNr + 1;
        item := item + page.GetString(lineNr);
    item := StringReplace(item,'<br />',#13#10);
    SetField(fieldDescription,ParserText(item,'<h2>Synopsis</h2>','</td>'));
    // Actors - Additional information - Related Anime
    lineAux := FindLine('Related Anime',page,lineNr);
    if (lineAux > -1) then begin
        info := INFO_START_TAG + 'Related Anime' + INFO_END_TAG + #13#10;
        item := page.GetString(lineAux) + #2;
        item := StringReplace(item,'<br>',#13#10);
        info := info + ParserText(item,'Related Anime',#2) + #13#10 + #13#10;
        lineNr := lineAux;
    // Number of Reviews, in reviews page
    lineNr := FindLine('More reviews',page,lineNr);
    numRev := StrToInt(TextBetween(page.GetString(lineNr),'More reviews (',')'),0);
    lineAux := lineNr;
    // Actors - Additional information - Opening Theme
    lineNr := FindLine('Opening Theme',page,lineNr);
    if (Pos('No opening themes found',item) = 0) then begin
        info := info + INFO_START_TAG + 'Opening Theme' + INFO_END_TAG + #13#10;
        item := ParserText(item,'Opening Theme',#2);
        item := StringReplace(item,'#',#13#10 + '#');
        info := info + FullTrim(item) + #13#10 + #13#10;
    // Actors - Additional information - Ending Theme
    lineNr := FindLine('Ending Theme',page,lineNr);
    if (Pos('No ending themes found',item) = 0) then begin
        info := info + INFO_START_TAG + 'Ending Theme' + INFO_END_TAG + #13#10;
        item := ParserText(item,'Ending Theme',#2);
    // Actors - Additional information - Fansubs
    lineNr := FindLine(fansub,page,lineNr);
        info := info + INFO_START_TAG + 'Fansubbing Groups' + INFO_END_TAG + #13#10;
    while (lineNr > -1) do begin
        group := TextBefore(page.GetString(lineNr),'</a>','') + #2;
        info := info + BlankAndCompact(ParserText(group,'>',#2),#9#13#10);
        groupTag := ParserText(page.GetString(lineNr),'<small>[',']</small>');
        if (groupTag <> '') then
            info := info + ' - [' + BlankAndCompact(groupTag,#9#13#10) + ']';
        groupTag := ParserText(page.GetString(lineNr),'<small>(',')</small>');
            info := info + ' - (' + BlankAndCompact(groupTag,#9#13#10) + ')';
        info := info + #13#10;
        lineNr := FindLine(fansub,page,lineNr + 1);
    SetField(fieldActors,FullTrim(info));
    // User Separator for Comments
    if (USER_CHAR_SEPARATOR <> '') then begin
        separator := StringOfChar(USER_CHAR_SEPARATOR,USER_SEPARATOR_LENGTH);
        if (separator = '') or (USER_CHAR_SEPARATOR = '_')
            then separator := separator + #13#10
            else separator := #13#10 + separator + #13#10;
        separator := #13#10;
    // Comments - Reviews
    if CanSetField(fieldComments) then begin
        if (numRev > 0) and FullReviews then begin
            // Destroy Details Page
            page.Free;
            // Create Reviews Page
            page.Text := GetPage(UrlEncode(reviewsAddress));
            lineAux := 0;
        lineNr := FindLine(userTag,page,lineAux);
            user := page.GetString(lineNr);
            if (Pos('<br />',user) > 0) then begin
                user := ParserText(user,'">','</a>');
                reviews := reviews + user + ':' + #13#10 + #13#10;
                revLine := FindLine('</table>',page,lineNr);
                    if (Pos(#9#9 + '</div>',page.GetString(revLine + 1)) = 1) then begin
                            review := review + page.GetString(revLine);
                            revLine := revLine + 1;
                        until (Pos('<div>',review) > 0);
                        review := StringReplace(review,'<br />',#13#10);
                        review := StringReplace(review,'read more</a>',' ');
                        review := ParserText(review,'</table>','<div>');
                        reviews := reviews + review + #13#10;
                        reviews := reviews + separator + #13#10;
                        review := '';
                    revLine := FindLine('</table>',page,revLine + 1);
                until (revLine = -1);
            lineNr := FindLine(userTag,page,lineNr + 1);
        SetField(fieldcomments,FullTrim(reviews));
    // Destroy Details or Reviews Page
    page.Free;
    // Picture
    if CanSetPicture then begin
        if (Pos(thumbPicture,pictureAddress) > 0) then
            GetPicture(UrlEncode(pictureAddress))
        else begin
            // Create Picture Page
            page.Text := GetPage(UrlEncode(pictureAddress));
            pictureTag := '<table id="dialog"';
            lineNr := FindLine(pictureTag,page,0);
            pictureAddress := TextBetween(page.GetString(lineNr),'<img src="','">');
            GetPicture(UrlEncode(pictureAddress));
            // Destroy Picture Page
            page.Free;
//----------------------MAIN-PROGRAM-------------------------
    if (CheckVersion(3,5,1)=FALSE) then begin
        ShowWarning('Required Ant Movie Catalog version 3.5 or higher');
        EXIT;
    if CancelBatch then EXIT;  // For remaining batch
    FullReviews := GetOption('Reviews') = 1;
    BigPicture := GetOption('Picture') = 1;
    BatchMode := GetOption('Batch Mode') = 1;
    SetPercent := GetOption('Set % Once') = 1;
    AtLeastOne := GetOption('At Least One') = 1;
    BM_MatchFind := FALSE;
    BM_BestResultPercent := -1;  // 0 is also an option
    BM_BestResultAddress := '';
    ExitNormalMode := FALSE;
    NumResults := 0;
    MovieName := GetMovieName(ALT_TITLE_SEPARATOR);
        if SetPercent
            then SettingPercentOnce
            else BM_Percent := DEFAULT_PERCENT;
        if CancelBatch then EXIT;  // For Cancel in SettingPercentOnce window
        AnalyzeForVariuosPages(MovieName);
    end else begin  // NormalMode
            if Input('MyAnimeList', 'Search:', MovieName)
                then AnalyzeForVariuosPages(MovieName)
                else ExitNormalMode := TRUE;
        until ExitNormalMode;
