Number of Movies to script ?
FinderX
Post by FinderX »
Is there any way to know the number of movies that script is going to change?
For example in the Scripting Window there are Movies Limits and the options All - Selected - Marks - Visibles
Is there a variable or function that tells me the amount of records to works?
th
FinderX
Well... the plan is...
Post by FinderX »
The idea is that once a window out in bathmode, with an input that set the porcentage of math title.
In summary, with use SetStatic store the value of percentage of title and GetStatic to read this value in bathmode.
But can not get the value of total record to work, selected before run the script (in the options all-selected-marks-visibles)
well... this is the prototype
procedure SettingPercent(var outputPercent:Integer);
    percentValue, durationValue : string;
    current: Integer;
    durationValue := GetStatic('duration');
    percentValue := GetStatic('percent');
    if (percentValue = '') then
        percentValue := IntToStr(defaultPercent);   // defaultPercent: global variable
    if (durationValue = '') then begin
        SetStatic('duration','0');
        durationValue := '0';
    if (durationValue = '0') then begin                  // First time of the bath
        // This Input appear in the first time ONLY
        if (Input('...', '...', percentValue)) then begin
            SetStatic('duration',IntToStr(***TOTAL_RECORDS***));
            SetStatic('percent',percentValue);
            outputPercent := StrToInt(percentValue,0);
            outputPercent := 0;     // Cancel button of the input
    end else begin                    // Here always for the rest of the bath
        current := StrToInt(durationValue,0);
        if (current > 0) then                 // This is like a counter
            SetStatic('duration',IntToStr(current - 1));
            // When 'duration' reaches zero
            // there is when is posible to set 'percent'
            // in theory...
