Template Help Please
Lasikie
Post by Lasikie »
Could Anyone tell me what I should change to this template to make it show the newest entries at the top instead of the bottom.
Thank You.
<html><head>
<style TYPE="text/css">
  text,body,p,div,span,th,td,ul,li { FONT-SIZE: 10pt; FONT-FAMILY: Trebuchet MS, Verdana, Arial, Helvetica, sans-serif; color: black; background: white; }
  HR { color: black; }
  A:link { COLOR: #003399; background: white; }
  A:visited { COLOR: #003399; background: white; }
  A:hover { COLOR: #CC0000; background: white; }
  A:active { COLOR: #CC0000; background: white; }
  td.blk { color: white; background: black; border: solid; border-color: black; }
  table.blk { color: white; background: black; border: solid; border-color: black; border-width: thin; }
  table.lgt { color: black; background: white; border: solid; border-width: thin; border-color: #F5F5F5; }
  td.lgt { color: black; background: white; border: solid; border-width: thin; border-color: #F5F5F5; }
  p.title { font-size: 18pt; font-weight: bold; }
</style></head><body>
<table class="blk" border="1" cellspacing="0" cellpadding="5"><tr>
<td class="blk" nowrap>Image</td>
<td class="blk" nowrap>Original Title</td>
<td class="blk" nowrap>Added</td>
<td class="blk" nowrap>Rating</td>
<td class="blk" nowrap>Resolution</td>
<td class="blk" nowrap>Link</td>
</tr>$$ITEM_BEGIN<tr>
<td rowspan="2" class="lgt"><strong>$$ITEM_PICTURE</strong></td>
<td class="lgt"><strong>$$ITEM_ORIGINALTITLE </strong></td>
<td class="lgt">$$ITEM_DATEADD </td>
<td class="lgt">$$ITEM_RATING </td>
<td class="lgt">$$ITEM_RESOLUTION </td>
<td class="lgt"><a href="$$ITEM_URL" target="_blank">$$ITEM_URL </td>
</tr><tr><td colspan="6" class="lgt">$$ITEM_DESCRIPTION </td></tr><tr><td colspan="7" class="blk"></td>
</tr>$$ITEM_END</table><p><strong>Total: $$TOTALMOVIES movies</strong></p></body></html>
Sorting order is not defined by the template: it is a setting in the export window. And currently it is not possible to reverse that order.
Lasikie
Post by Lasikie »
thanks for the info ,will this be a future option?
It is in the to-do list but I do not know when I'll continue to work on the program...
henrifos
Post by henrifos »
.... I do not know when I'll continue to work on the program...
Sorry to hear that. How can we encourage you? :hihi:
If I did not had to sleep each day I would have more time...
Or if I did not had to go to work.
So as you see, it is not easy to find time :D
